Old January 4, 2010, 04:11 AM
Default System Stability Test
[Main thread Jan 4 07:16] Mersenne number primality test program version 25.11
[Main thread Jan 4 07:16] Starting workers.
[Main thread Jan 4 14:56] Stopping all worker threads.
[Main thread Jan 4 14:56] Starting worker.
Builded a new rig stock and not overclocked, and its running for more then a week now. I wanted to know if everything was going good and did a test with Prime95 64bits. As the whole system set up is still on a 30day warranty. Is this the right program to use for testing stock systems? What other test can i do to make sure everything is good?
System was running and didnt crash at all during the test till i stopped it at the above time. Is there a report i should be taking note if it did?
Old January 4, 2010, 04:34 AM
burebista's Avatar
7 hours of prime95 is good enough. :)
You can try Furmark for your GPU too or a Power Supply test from OCCT.
If it ain't broke... fix it until it is.
Old January 4, 2010, 05:18 AM
kendallcschm's Avatar
pcmark
3dmark
and prime 95
if you have an AMD system you can use AMD overdrive
Old January 4, 2010, 03:29 PM
Perineum's Avatar
I like using furmark and atitool at the same time, that way I can see artifacting....
Old January 12, 2010, 01:55 AM
Thank you so much for all your suggestions. Really appreciate!
Old January 12, 2010, 05:53 AM
Finch's Avatar
i would also use memtest to test memory
If you are an overclocker please come and participate to the HWC Benchmarks Competitions, look for the stickies.
Old January 12, 2010, 06:26 AM
MarkOne's Avatar
When you afraid of something, it happen, to much worry here, just relax and enjoy your system
Old January 12, 2010, 10:28 AM
Eldonko's Avatar
Hardware Canucks Reviewer
I find Linpack is the best personally. Info here
Old January 12, 2010, 12:38 PM
Eldonko, OCCT actually has a Linkpack test in their new versions, they claim it's based on IntelBurnTest.
Furmark definitely for GPU stress test. Prime 95 or OCCT for CPU test, good old dos based memtest for memory testing, 3dmark05/06 for stability testing. If you're just overclocking quick to run benchmarks, you might escape with a quick 30 mins or 1hr stress test (cpu/gpu/mem), if you're looking for a stable overclock that you will use everyday, might want to run the stress tests for a good 8-10 hrs.. Prime95 sometimes passes 6-7hrs and then starts picking a crap load of errors..
Good Luck..
Old January 12, 2010, 03:01 PM
Highest resolution Furmark, 8X AA and xtreme burning settings will quickly heat your GPU up.
IBT/LinX (same program) ran at maximum or very high settings should pretty damn quickly show you if it's stable or not.
5 completions = pretty stable. 20 completions = more stable than you will ever need.
HDD fails S.M.A.R.T. short test, but passes long test? frontier204 Storage 10 May 19, 2011 04:10 PM
I7 920 with 12GB 1600mhz ddr3, HELP with system stability issues!!! HH89 Troubleshooting 25 October 3, 2009 01:34 AM
HWC New GPU Test System + Games SKYMTL Video Cards 30 March 29, 2009 08:06 AM
Programs that can test GPU stability? Silvgearx Video Cards 19 March 11, 2009 08:43 PM
OS Stability Question CORE O/S's, Drivers & General Software 11 January 5, 2009 12:04 AM
