Old December 30, 2009, 04:24 PM
Draex's Avatar
Default i5 750 voltage?
Revisiting overclocking my i5, currently 8 hour stable at 200x20, 1.344vcore (rest set to auto) and getting about 75C load temp (prime95 blend) and wanting to see if I can get my temps down any lower well retaining 4 ghz, should I try backing down the vcore more? or is there other voltages I should try and set/reduce?
(Motherboard is a P55-UD4P)
Thanks in advance.
Old December 30, 2009, 04:41 PM
MarkOne's Avatar
so my 65'c for a 200x20 on 1,31 vcore was not a bad temp.. what kind of cooling solution you have ?
Old December 30, 2009, 04:43 PM
Draex's Avatar
Noctua NH-U12P SE2 with the stock fans on it.
Old December 30, 2009, 05:01 PM
MarkOne's Avatar
try slowly step by step to go down to 1,30 , my 1,31 was with the auto mode of an Asus board , they are usually generous
Old December 30, 2009, 07:29 PM
Draex's Avatar
It seams to lose stability at 1.30v but is running fine at 1.31, changing the QPI/VTT from anything other then Auto seams to make the system crash, the temperature overall seams to be unchanged for the most part. Could it be I need to remount the HSF? Also I should point out that the ambient temp in the room is 30C, Ambient temp measured in the case (Infrared temp probe) is 42C.
Old December 30, 2009, 07:44 PM
MarkOne's Avatar
you have a room at 30'c in this time of the year ?... that's explain the difference in temps.
Old December 30, 2009, 07:52 PM
Draex's Avatar
The room hits 30C without the baseboard heaters on just from my two folding systems running. It drops down to about 14-15C with them off.
*EDIT*
I have made another discovery, I removed the side panel from my ATCS840 and the temps on both video cards and the CPU droped by ~10-15C under load. I am wondering if this is because of the stock cooling setup on the ATCS840 (lots of exhaust but little air intake)
Old December 30, 2009, 08:18 PM
BobbyLou's Avatar
Thanks in advance.
try reseating the cooler. I use the same and at 1.32 vcore 200blk I got around 65 max
Old December 30, 2009, 08:33 PM
Draex's Avatar
I am getting 61C on the hottest of the Cores after removing the side panel, should I still try and re-seat the HSF?
Old December 30, 2009, 08:49 PM
MarkOne's Avatar
on your cooler master ?.......... 61'c is pretty good.. I will work on the ventilation of the case instead, may be you can add a fan at the bottom of the case. and may be somethink like this on the front bay
NCIX.com - Buy Thermaltake iCage 5.25IN To 3.5IN Aluminum Drive Bay Convertor W/ 120MM Blue LED Fan - A2309 In Canada.
I use those cage on many of my server and PC. I purchase 30 of them when they was at $ 14
Which is the best? 750 or 860 MarkOne Overclocking, Tweaking and Benchmarking 6 December 31, 2009 05:40 AM
i5 750 @ 4ghz Fudd Rucker Overclocking, Tweaking and Benchmarking 4 December 16, 2009 11:56 AM
I5 750 Problem MikeScott Overclocking, Tweaking and Benchmarking 27 November 27, 2009 03:05 PM
