Old December 30, 2009, 10:06 PM
Draex's Avatar
Right now the cooling is stock on the case, The two top fans and rear mobo fan are exhausting, the one front fan is the only intake from what I can see, and its airflow is mostly blocked by part the sticks out at the front, the CPU HSF fan is blowing air to the rear exhaust fan, here is a side profile of the empty case.
http://ak.cdiscount.com/pdt/4/0/B/4/f/ATCS840B.jpg
I am thinking adding the front intake fan, and bottom fan like you suggested plus maybe cutting and putting a fan grill with a larger fan blowing in on the side panel.
Old December 31, 2009, 07:04 AM
gingerbee's Avatar
put more intake fans. positive pressure is what you want heat rises. or just leave the side panel off and your temps look great i would not reset the heatsink. @ 30c in my apt on water i can hit 70c so (i7 920 @3.8 1.21vcore max temps every seen was 77c @ ambient 0f 30c with ht on )
YouTube - Sugo SG03 SFF case positive air pressure demonstration
YouTube - Fortress FT01 PC case with positive air pressure part 2
Which is the best? 750 or 860 MarkOne Overclocking, Tweaking and Benchmarking 6 December 31, 2009 06:40 AM
i5 750 @ 4ghz Fudd Rucker Overclocking, Tweaking and Benchmarking 4 December 16, 2009 12:56 PM
I5 750 Problem MikeScott Overclocking, Tweaking and Benchmarking 27 November 27, 2009 04:05 PM
