  #21 (permalink)
Old December 18, 2009, 03:45 PM
Originally Posted by ayah View Post
But with the 1.375v being max stock voltage, that's pretty much a guaranteed 100% safe voltage if Intel will set it on their chips from the factory.
Yes. However, 1.375V is not the highest safe voltage. You can go higher than that without risking damage to the CPU. That's the point I'm trying to make.
Now, I don't actually recommend going too far above 1.375V, since 1.4V is pretty much the limit on air before you start running into unmanageable temps.
  #22 (permalink)
Old December 22, 2009, 11:15 AM
According to Intel, max is 1.375v. And I had to run 1.42v to keep mine stable at 4.2ghz
  #23 (permalink)
Old December 22, 2009, 11:18 AM
No, that's just the upper limit of the VID range. I explained that already in my previous posts.
  #24 (permalink)
Old December 22, 2009, 12:41 PM
Sagath's Avatar
Yes Zero. You did. But reading is hard. k?
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
Max Load On Intel i7 920 ? JORD4N CPU's and Motherboards 18 January 26, 2010 07:30 AM
Voltage Questions - i7 920 ChuckleBrother Overclocking, Tweaking and Benchmarking 6 May 1, 2009 10:37 AM
920 OC Voltage questions SugarJ Overclocking, Tweaking and Benchmarking 3 March 5, 2009 08:45 AM
X48 Max Safe NB Voltage for 24/7 use? soapman72 Overclocking, Tweaking and Benchmarking 6 July 13, 2008 10:21 AM
max dc voltage in north america? Fr0sty Power Supplies 6 August 12, 2007 08:46 PM
