Originally Posted by bkh2 Thanks for that link. It's exactly what I needed. Are you sure some shipped with a 1.375V stock? That seems very odd, but if it's true, I'd feel a lot better about pushing up my voltage to at least 1.25-1.3V. |
My guess is none shipped that high, no. But what it does mean is that due to the nature of manufacturing
anything the engineers behind i7 have to design the chips within a tolerance of operation. That range caps out at 1.375. It just so happens the manufacturing process is better then expected so the tolerance max and never reached a VID of 1.375v on a retail processor.
Like any sort of advice, take it with a grain of salt. Its your chip and I'm not an Intel engineer.
Do what you want, under your own risk.
That being said: From all the people on the net, and even these forums, Ive yet to hear of a chip dying due to being overclocked at even 1.4v. Assuming its being properly cooled. If you take the proper steps and
stress test it properly you wont have any issues. Your screenshot shows a 2 min prime at 4ghz at 85c, to me this is NOT a sucessful 4ghz overclock. That chip would probably hit 100c after a bit of time, like oh, another 3 min
. I know Id be crapping my pants if I clicked start on P95 and saw my temps jump to 85c
Anyways, the point is, we can tell you all we/you want that X volts is safe. But its up to you to do it under your own risk, because there is always some risk with ANY overclocking.
