Old December 15, 2009, 01:23 PM
Fudd Rucker's Avatar
Default i5 750 @ 4ghz
Got my i5 under water finally, loop is in my sig
CPU-Z Validator 3.1
Idle temps are roughly 35*C and stayed at 68*C during an hour long linpack test.
Primed it for 4.5 hours ran just fine figured thats good enough no? I usually dont stress my machine for that long of a period of time.
I couldnt think of something snarky or interesting to put here this time around.
Old December 15, 2009, 01:53 PM
MarkOne's Avatar
you get that on water ? I have similar result with a 212+
Old December 15, 2009, 01:57 PM
i think my problem is this lancool sucks ass for a decent watercooling loop. Im thinkin after xmas im going to get an HAF or a 1200 and mount a much bigger and meaner radiator, that should improve temps considerably.
Old December 16, 2009, 12:01 AM
Oversized Rooster's Avatar
Interesting...yeah your temperatures aren't great at all given that you're using water.
With my 860 I reach 4GHz with about 1.33V and using a Thermalright Ultra-120 Extreme with 2 fans, I get exactly the same idle and load temps as you...minus water, tubes, radiators, etc.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old December 16, 2009, 12:56 PM
misterd's Avatar
Nicely done. Dibs on the Lancool!
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
i7 4ghz :D vagnaar Overclocking, Tweaking and Benchmarking 18 January 16, 2010 01:41 PM
P6T i7 920 3.4GHz??? sinticfury Overclocking, Tweaking and Benchmarking 3 August 20, 2009 07:57 PM
OC E7200 from 3.73Ghz to 4Ghz geokilla Overclocking, Tweaking and Benchmarking 1 May 3, 2009 01:04 PM
The Magic 4GHz NyteOwl Overclocking, Tweaking and Benchmarking 15 September 8, 2008 06:46 PM
4Ghz Q6600 Prime stable turtletrax CPU's and Motherboards 14 August 13, 2007 10:05 AM
