Old December 14, 2009, 07:17 PM
vagnaar's Avatar
Default i7 d0 4.2ghz
Hey everyone! i got 4.2ghz on my i7 d0 stepping
CPU-Z Validator 3.1
i even got my memory to 1600mhz 8-8-8-24 :)
now i think my CPU vcore is a bit high though, its at 1.35v
my temps are about 47c idle and 85 was max i saw with Intelburntest set to max
So far i have had no instabilities, i ran a couple things like Intelburntest and Hyper pi
what do you guys think?
[Desktop] |i7 3770K|8GB Patriot Viper DDR3|Seagate Momentus XT 500GB|Seagate Barracuda XT 3TB|EVGA GTX 660Ti|CM690II Advanced Nvidia|
Old December 14, 2009, 07:28 PM
MarkOne's Avatar
is 85'c not a little bit hot ? what are you using for cooling ?
Old December 14, 2009, 07:58 PM
85C is still within the "safe" boundary. I'd lower the overclock for 24/7 use though personally.
Intel Core i7 920 4.1GHz w/ Thermalright U-120E
24GB G.Skill 1.25v DDR3-1600 9-9-9-24
eVGA 758 - A1
80GB Intel X25-M G2
1TB WD Black
1.5TB Seagate 7200.11 (still works!)
10.9TB RAID6 Samsung F4EG
XFX 5850 @ 1000/1250 w/ Scythe Setsugen
2X Dell U2412M Seasonic M12 850W
Old December 14, 2009, 08:09 PM
martin_metal_88's Avatar
Personally I would not let my CPU run at this temp but that in the ok zone. Always depend on the user;) Nice to see this memory running this fast! now get faster memory and go higher:P
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old December 14, 2009, 08:10 PM
get a better cooler
i got the megahalems and i get 80c @ 4.5 while priming
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old December 14, 2009, 08:12 PM
Originally Posted by zsamz_ View Post
get a better cooler
I thought IBT got hotter than prime.
Old December 14, 2009, 08:36 PM
It does.
eVGA 758 - A1
80GB Intel X25-M G2
1TB WD Black
Old December 14, 2009, 08:54 PM
vagnaar's Avatar
I have Corsair h50 with push pull setup, and yea intel burn test is hotter, i get around 80 with prime95, i may try to drop voltage to see if i can get it a bit cooler
Old December 14, 2009, 09:07 PM
3oh6's Avatar
Hardware Canucks Reviewer
85C with IBT is definitely not a problem. if it don't bounce of the rev limiter, it is fine. keep in mind, during every day use, your system will absolutely NEVER see the load that IBT puts on it...unless you crunch or fold. even still, those programs will be less heat than even Prime which likely will keep them well below 80C which is completely safe. sounds like you have a stable and good overclock, leave it there and enjoy the system is my advice.
Old December 14, 2009, 09:21 PM
gingerbee's Avatar
@^bingo
P6T 3.8 to 4.2ghz - voltage difference. MittWaffle Overclocking, Tweaking and Benchmarking 4 August 2, 2009 12:09 PM
[FS] Core2Duo E4500 2.2Ghz 2MB Bradan Buy/Sell & Trade 1 March 21, 2009 11:23 AM
[FS] E4500 11x200=2.2ghz 2MB Bradan Buy/Sell & Trade 6 March 18, 2009 05:29 AM
FS: 4.2GHz E8400 zlojack Buy/Sell & Trade 3 September 11, 2008 07:29 AM
C2D E6400@ 3.2Ghz Needs Advice Please?! bushwickbill Overclocking, Tweaking and Benchmarking 8 January 18, 2008 10:18 AM
