Well I want to know any info because I have never overclocked a CPU before (always had a mobo that didn't have overclocking features). My comp's spec are in the sig. Also I am lazy would I be able to bump the FSB to 350? 350 is the maximum I want to to go for now. Also memory frequency you times by 2 right? It says it is at 400mhz that is 800mhz right? - noob question hehe.
__________________ Intel Core 2 Quad Q9550 @ 3.6, Asus Formula Maximus X38, 2 x 4 gigs of DDR2 1000 mhz, 1 TB sata HD, 18x DVD burner, Visiontek 4870 X2, Sound Blaster X-Fi extreme music, G15 and G5 keyboard and Mouse, crappy 5.1 speakers, Dell 24" 2407WFP, Enermax Galaxy 1000w. Lots of cooling. Cooler Master Cosmos 1000. http://www.cybernations.net A Nation Simulation Game Last edited by belgolas; September 22, 2007 at 09:01 AM. |
You need to get some overclocking tools first. Download the newest CPU-Z off of CPUID - This will give you specs of your processor, motherboard and ram. Download coretemp, this will tell you your temperature of each core in your CPU. Coretemp does bug with G0 stepping quads, so be sure to add ~10ēC to your given temperature to be safe. You can also download speedfan, it also gives you a temperature reading, but uses a different sensor on the CPU. Log into BIOS and set your CPU an increment or two above stock, put your ram to 2.2V, and use timings 5-5-5-15. This will allow you to have quite a bit of headroom for overclocking. Next, raise your CPU FSB in 5MHz increments, making sure that you can log into Windows from there. When you find your best CPU speed, but is unstable in Windows, you must either back down on your overclock or bump up the CPU voltage a bit until you reach stability. You might need to bump up your NB voltage when reaching higher FSB speeds. The max Vcore on air that I would recommend is 1.45V, and 1.55V on water. The max temperature an overclocked Q6600 should be no more than 60ēC loaded. After you find your "stable" overclock, you must start and run a program called Orthos for a minimum of 10 hours. This program puts your CPU under load, making sure your system is stable. Be sure to watch your temperatures when running this program. (You have a quad core, so you'll need to run two instances of this program) Let me know if this works out, You should be able to get 3.0ghz with this method, report in after you reach that stable overclock.
__________________ [ER] |
O.K. I was scared to do it myself so I let it overclock it self with C.I.A.2 at racing witch is 11%. That is 2.78ghz. I am fine with that. If I went to 19% it wouldn't go into windows BSOD. 17% I ran orthos for 2 minutes and system reset itself. So 11% it is. Now the wierd thing id SpeedFan says that Core 0 and 1 are 53 and 51 while core 2 and 3 are at 39 and 34. Temp 1 is at 51 and temp 2 is at 55. I have been running 2 orthos at about 10 minutes now. I think I have to reset the heat sink. Also core 2 and 3 are at 0 % usage with 2 orthos running.
__________________ Intel Core 2 Quad Q9550 @ 3.6, Asus Formula Maximus X38, 2 x 4 gigs of DDR2 1000 mhz, 1 TB sata HD, 18x DVD burner, Visiontek 4870 X2, Sound Blaster X-Fi extreme music, G15 and G5 keyboard and Mouse, crappy 5.1 speakers, Dell 24" 2407WFP, Enermax Galaxy 1000w. Lots of cooling. Cooler Master Cosmos 1000. http://www.cybernations.net A Nation Simulation Game Last edited by belgolas; September 22, 2007 at 10:10 AM. |
O.K. So I decided to go back to manual overclock and am having trouble going over 280 FSB. ![]() had to shrink my screen size to 1024 x 768.
__________________ Intel Core 2 Quad Q9550 @ 3.6, Asus Formula Maximus X38, 2 x 4 gigs of DDR2 1000 mhz, 1 TB sata HD, 18x DVD burner, Visiontek 4870 X2, Sound Blaster X-Fi extreme music, G15 and G5 keyboard and Mouse, crappy 5.1 speakers, Dell 24" 2407WFP, Enermax Galaxy 1000w. Lots of cooling. Cooler Master Cosmos 1000. http://www.cybernations.net A Nation Simulation Game |
More vcore will allow higher FSB on some mobos. Also, if possible, bump NB voltage as well.
__________________ - EVGA 680I A1 - QX6800ES G0 @ 3.95Ghz - SLI BFG 8800GTX @ 626Mhz \ 2000Mhz - 4GB G.SKILL F2-6400PHU2-HZ @ 1000Mhz - Ultra X3 1000 Watt - X-FI XtremeMusic \ Klipsch Promedia 2.1 THX - WD RaptorX 150GB \ WD500GB \ WD Caviar 250GB - MountainMod U2-UFO Black Powder Coat - Dell UltraSharp 24'' Loop #1 : D-Tek FuZion - 2x MCW30 - Cyclone Res - MCP355 w/ Petra's Top - PA120.3 - Tygon Loop #2 : 2x Ek-FC 8800GTX - Ek 150 Rev.2 - MCP355 w/ Petra's Top - PA120.2 - Tygon |
I added more juice and nothing :(. I think I will give up on overclocking. Not like my CPU isn't good enough already :p.
__________________ Intel Core 2 Quad Q9550 @ 3.6, Asus Formula Maximus X38, 2 x 4 gigs of DDR2 1000 mhz, 1 TB sata HD, 18x DVD burner, Visiontek 4870 X2, Sound Blaster X-Fi extreme music, G15 and G5 keyboard and Mouse, crappy 5.1 speakers, Dell 24" 2407WFP, Enermax Galaxy 1000w. Lots of cooling. Cooler Master Cosmos 1000. http://www.cybernations.net A Nation Simulation Game Last edited by belgolas; September 22, 2007 at 12:19 PM. |
Well I just found some new hope! I decided to try again and well first I tried 340 FSB with voltages to manual and ram set to auto (it was set at 1080). That failed. So I tried at 360 FSB(cause I heard of FSB walls) and set voltages to auto and ram to manual at 900 and that worked. So far only 42c in all four cores and 3.240.2 GHZ Running four orthos and will let you know if stable. Me verrrrrrrrrryyyyyyyyyyy happy!
When I ran at 360 the system felt slower and some stuff like opening MyComputer was slower. When I went to 340 the system was notably faster. 360 unstable now trying 340. So far stable and got a 12176 on 3DMark06.
__________________ Intel Core 2 Quad Q9550 @ 3.6, Asus Formula Maximus X38, 2 x 4 gigs of DDR2 1000 mhz, 1 TB sata HD, 18x DVD burner, Visiontek 4870 X2, Sound Blaster X-Fi extreme music, G15 and G5 keyboard and Mouse, crappy 5.1 speakers, Dell 24" 2407WFP, Enermax Galaxy 1000w. Lots of cooling. Cooler Master Cosmos 1000. http://www.cybernations.net A Nation Simulation Game Last edited by belgolas; December 26, 2007 at 11:05 AM. |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Overclocking Guides | Babrbarossa | Overclocking, Tweaking and Benchmarking | 15 | September 22, 2008 09:16 AM |
| 8800GT Bios Flashing Guides | MajorBuzzon | Video Cards | 3 | June 1, 2008 11:34 PM |
| Tips to clean radiator | eagle_ | Water Cooling | 2 | August 22, 2007 08:28 AM |
| Overclocking E6420 and DFI P965-S on water.. need some tips | Somed00d | Overclocking, Tweaking and Benchmarking | 14 | July 19, 2007 10:14 AM |
| tech toy guides and faq guides. | Il Duce | Suggestions & Feedback | 0 | April 10, 2007 07:08 PM |
