  #21 (permalink)
Old January 16, 2008, 12:42 PM
belgolas's Avatar
Level up: 79% Level up: 79% Level up: 79%
Level: 17 - 168 points to level up
Ah OCZ Platinum Edition Rev. 2. 4x1gig.
Intel Core 2 Quad Q9550 @ 3.6, Asus Formula Maximus X38, 2 x 4 gigs of DDR2 1000 mhz, 1 TB sata HD, 18x DVD burner, Visiontek 4870 X2, Sound Blaster X-Fi extreme music, G15 and G5 keyboard and Mouse, crappy 5.1 speakers, Dell 24" 2407WFP, Enermax Galaxy 1000w. Lots of cooling. Cooler Master Cosmos 1000.
http://www.cybernations.net
A Nation Simulation Game
  #22 (permalink)
Old January 16, 2008, 02:43 PM
belgolas's Avatar
Well it didn't matter if I had 2 or 4 sticks. I even tried 7,8,8,20 and still nothing.
  #23 (permalink)
Old January 16, 2008, 03:30 PM
Level up: 9% Level up: 9% Level up: 9%
Level: 13 - 441 points to level up
have you tried a lower cpu multi and a higher fsb, this can tell you if it is a fsb wall or a cpu wall.
If you try 6x300 (for example) and get no where, but 4x400 works fine, then it may be a cpu limitation (my problem), but if its the opposite then it may be a fsb issue
My komPuter - Mobo P35-DS3L rev2 CPU e6750@3.2GHz CPU Cooler: TRUE w/2xNF-SP12's RAM:2x1GB Ballistix@800 GPU:x1950pro GPU cooler :AC Accelero S1 Case: Antec 900 PS: Antec SP-500 Monitor:Samsung 931c
  #24 (permalink)
Old January 16, 2008, 03:42 PM
Prof. Dr. Silver's Avatar
Hardware Canucks Reviewer
But you're running PC2-6400?? That normally runs 800MHz on 4-4-4-15-2t...and now you're trying to run it at 1000MHz....I do not believe your RAM can do that....the highest mine could do was 950 @ 5-5-5-15 2t and I had it normally running at 900MHz at 4-4-4-12-2t, which is still pretty reasonable. See if you can use another mem divider....
  #25 (permalink)
Old January 16, 2008, 04:13 PM
belgolas's Avatar
I could even run it at 800 mhz and still nothing.
  #26 (permalink)
Old January 16, 2008, 04:28 PM
What is the stock voltage on that quad? Maybe you want to set it a tad higher (between 1.35 - 1.40V ???) and then try 8x400 (3.2GHz) for example....leave the memory at 800MHz....also try 7x500 (3.5GHz) or 9x400 (3.6GHz) Play around with these settings a bit and see what works best!...Start low at 3.2 with the lowest voltage...and go up from there.....! Good Luck
  #27 (permalink)
Old January 16, 2008, 04:43 PM
belgolas's Avatar
thanks will try in awhile.
  #28 (permalink)
Old January 23, 2008, 11:22 AM
belgolas's Avatar
Well the highest stable overclock I could get was 425x8 so 3.4 GHZ. Also the lowest multiplier for memory is 2.0. 3DMark 06 score with a slight overclocko n GPU is 12257
Futuremark - ORB - Result Analyzer
  #29 (permalink)
Old January 24, 2008, 04:44 PM
belgolas's Avatar
3.4 ghz is a little unstable. Was folding and downloading over night and the comp restarted. So I will probably bring it down to 3.2 GHZ.
Overclocking Guides Babrbarossa Overclocking, Tweaking and Benchmarking 15 September 22, 2008 09:16 AM
8800GT Bios Flashing Guides MajorBuzzon Video Cards 3 June 1, 2008 11:34 PM
Tips to clean radiator eagle_ Water Cooling 2 August 22, 2007 08:28 AM
Overclocking E6420 and DFI P965-S on water.. need some tips Somed00d Overclocking, Tweaking and Benchmarking 14 July 19, 2007 10:14 AM
tech toy guides and faq guides. Il Duce Suggestions & Feedback 0 April 10, 2007 07:08 PM
