so far it has been stable.
__________________ Intel Core 2 Quad Q9550 @ 3.6, Asus Formula Maximus X38, 2 x 4 gigs of DDR2 1000 mhz, 1 TB sata HD, 18x DVD burner, Visiontek 4870 X2, Sound Blaster X-Fi extreme music, G15 and G5 keyboard and Mouse, crappy 5.1 speakers, Dell 24" 2407WFP, Enermax Galaxy 1000w. Lots of cooling. Cooler Master Cosmos 1000. http://www.cybernations.net A Nation Simulation Game |
Sunbeam Tuniq Tower
Are you using 4 ram sticks? If so, have you tried oc'ing with 2? Have you tried a higher FSB? My Q6600 does 400 stable (under water) on my DS3L.
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
4 ram sticks and no. Also my northbridge can get hot.
Try 2 sticks and put a fan on top of that NB. I know it does get really hot, since it is really small in size. I added a SpotCool fan and reached 400 FSB.
WOW I never knew about that fan. I have been searching for the right fan for my northbridge but since the tuniq tower is so big I couldn't find a good one. I might just buy a couple thats if I have enough spots to connect the three pin to mobo. Thanks a TON!
Anytime. Those Antec SpotCool are great little fans. And your oc wall just might have been a NB overheating.
Well I have installed the new fans and have 2 spot cool fans over the northbridge area and no matter what I do I can't get to 400 FSB. So I tried 380 and I can boot but when I tried Orthos it goes for about 2 minutes and then the program shuts down. So I tried a memory/CPU test and it says I get an error. I have found out that my memory is most likely the problem cause I can't get the memory over 1000 mhz even with loose timings and right now it is set at 912. So system seems stable but going to try 3dmark and crysis to see If I get anything weird. So any help? Should I try with only 2 sticks? Maybe better ram?
Try 2 sticks with loose ram timings first - what the ram you're using btw?
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Overclocking Guides | Babrbarossa | Overclocking, Tweaking and Benchmarking | 15 | September 22, 2008 09:16 AM |
| 8800GT Bios Flashing Guides | MajorBuzzon | Video Cards | 3 | June 1, 2008 11:34 PM |
| Tips to clean radiator | eagle_ | Water Cooling | 2 | August 22, 2007 08:28 AM |
| Overclocking E6420 and DFI P965-S on water.. need some tips | Somed00d | Overclocking, Tweaking and Benchmarking | 14 | July 19, 2007 10:14 AM |
| tech toy guides and faq guides. | Il Duce | Suggestions & Feedback | 0 | April 10, 2007 07:08 PM |
