-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   New Q6600 (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/2647-new-q6600.html)
Asspigeon September 21, 2007 09:32 PM
New Q6600
I just finished setting up my new computer and I ran Prime95 for about 20 minutes to see what my temps would be like. According to Gigabyte EasyTune5 I am looking at 34~35c under full load. :clap:
How fast do you guys think I can get this processor to go with temps like that!?
Cptn Vortex September 27, 2007 12:53 AM
I would run CoreTemp first....My quad doesn't even idle that low....
JD September 27, 2007 07:20 PM
Gigabyte EasyTune probably isn't accurate at all. Definitely run CoreTemp or SpeedFan.
pscout September 27, 2007 08:11 PM
on the giga mobo's i have with quads i find easytune reads the same temps as speedfan and ~ 15C lower than coretemp.
It is consistent tho so use whichever you want ... i can't stand the crappy interface in easytune so i uninstalled it and use mostly coretemp.
Speedfan doesn't read much else right for me but i use it a bit for vc readings rather than a current cpu-z just to get an idea of how much vdroop i am getting.
Asspigeon October 1, 2007 11:35 AM
Quick newbie question, once I find my maximum FSB with the stock multiplier, how much of a performance increase am I going to see if I lower the multiplier to increase memory bandwidth?
I was just planning on just increasing the FSB while leaving the memory settings on auto (GA-P35-DS3R). Am I going to see a large improvement if I handle the memory settings manually?
sswilson October 1, 2007 11:46 AM
If the bios on the DS3R handles auto mem settings the same way the DQ6 does you'll see a huge benefit by tweaking your memory settings after you find a stable CPU OC.
The one of the main reasons the DQ6 is so easy to OC is the extremely loose auto memory timings it sets as you ramp up FSB.
As far as changing multis goes for maximizing your bandwidth... it depends a lot on your memory, and the FSB you end up at.
Most times you can make up for slow(er) memory clockspeeds by tightening up the timings, but if you've got a set of memory that doesn't want to do 4-4-4-X at 850ish, you may find that the 5-5-5-X you need to set for 850ish will scale up pretty high beyond that without any tweaking and get you better bandwidth.......
Asspigeon October 1, 2007 12:15 PM
I am currently using 2 gigs of OCZ Reaper DDR2800 with stock timings of 5-5-5-15.
Asspigeon October 1, 2007 12:59 PM
I have having some problems with my voltages and multiplier. CPUZ seems to be waffling between a 6x multiplier and a 9x multiplier (set to 9x in bios). Also my CPU voltage seems to be different depending on where I check, CPUZ and EasyTune5 are showing different voltages.
I originally set the FSB to 320 but received a bsod when I started Prime95. This is confusing because my CPU & System temps were both 46c when it happened, which I thought was a decent temp.
http://img411.imageshack.us/img411/1...ock2cb2.th.jpg
sswilson October 1, 2007 01:31 PM
If the multiplier is jumping around like that then you have one of the cpu power saving / cpu throttling settings enabled in bios.
I think it's the second or third bios "folder" from the top... it's the one that has virtualization in it.
Asspigeon October 1, 2007 02:28 PM
Do you know the name of the setting I need to disable? There are several that seem to pertain to the CPU overheating and I don't want to disable the wrong one.
