I can't seem to get my FSB above 310. As soon as I set it to 320 or 330 I can't even boot into the bios. This is weird because my temps are low (never above 46) and 310 appears to be rock solid. I am letting the mobo do the volts and memory for the moment. 310 x 9 = 2790mhz I will leave Prime95 running while I sleep and hopefully I can squeeze a bit more from it tomorrow. If anyone has any ideas about how to get it going a little faster please post. |
Well, reading through the thread, it sounds as though you have not adjusted ram speed? So, when you up the FSB, you up the ram speed as well. If you look at your last screenshot, your ram is @ 900mhz. That there reaper ram isn't known to overclock all that well. it will go a bit, but... So, in bios, you need to change a few things. Dropping the ram divider will probably let you get a bit further... What board do you have exactly? |
Yeah, so do you know how to adjust this? That would be the first place to start. Your attempt at a lower multi but same cpu speed kinda confirms this. So, lower the ram divider, then up the FSB more and see what happens. Also, if you have the "4-4-4-12, 1T" Reapers, don't be afraid to give them 2.2v...or a bit more...just make sure they are getting good airflow for more than 2.2v! |
Excellent that solved it, I just booted at 330 x 9 = 2970. I am running Prime95 again and am still seeing CPU temps in the mid 40s. I left it on all last night and woke up to 46 (I love this cooler - Tuniq Tower). Noob question inc: Do I want to set my system memory multiplier high or low for best performance? I booted successfully at 2.5 and I'm not sure where to go from here. My memory is of the DDR2800 variety and runs on timings of 5-5-5-15. My second question is what are the pros/cons of lowering the CPU clock ratio? I currently have mine set to the stock 9 but I know lowering it has an effect on the memory (more bandwidth?). Do I want it as high as possible or as low as possible and why? |
I have a a ds3r with a q6600 G0 running at 365x9 with mushkin 6400 memory at 4:5 ratio (= 912) with 4-5-4-11 stock timings @ 2.2V. Settings: - vc = 1.35 (vdoop results in speedfan/cpuz showing 1.24V under load) - vMch = +.3 - vfsb = +.2 - C1E and EIST are disabled. - VT is enabled since i am running vmware on it with 2 linux vms each folding 724 for more than a month now. My initial oc was running at 370x9 with the same settings but during some hot days it would reboot probably due to high nb temps, so i lowered fsb to 365 and it has been stable ever since. Once you find your max stable oc for the cpu with memory at 1:1, then you try to raise your memory speed. For foldingm, maximizing memory bandwidth is my objective, so higher memory speed is more important than tight timings. If you like to get high benchmark scores, tighter timings might be beneficial. Finding a sweet spot when vc is at a miniumum, temps are lowest, and performance of your favoured application(s) is the best involves experimentation, testing and measurment to find the best mix for you. Lowering the multi means you need a higher fsb and this will affect both cpu oc setting and memory. For me, it is easy (but time consuming) to measure the performance of my favoured application (folding) since I can repeat the exact same workload repeatedly with different settings and measure its performance (time per frame) as well as power consumption and temperatures. If you are only gaming, then use one of the game based benchmark tools that most closely resembles your game. Last edited by pscout; October 2, 2007 at 03:31 PM. |
| Quote:
400/9=44.4 450/8=56.25 515/7=73.57 and so on... |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wtb: Q6600 G0 | m4xn00b | Buy/Sell & Trade | 0 | February 29, 2008 03:41 AM |
| q6600 vs e8400 | enaberif | Overclocking, Tweaking and Benchmarking | 39 | February 21, 2008 03:57 PM |
| Oem Q6600 | Brando737 | CPU's and Motherboards | 2 | December 16, 2007 01:22 PM |
| DirectCanada & Q6600 processor | RacerX | CPU's and Motherboards | 15 | December 11, 2007 06:55 PM |
| New G0 Q6600 | coldmeat | CPU's and Motherboards | 124 | November 5, 2007 01:36 AM |
