Old December 9, 2009, 09:56 PM
mattlef's Avatar
Default AMD 550 @ 3.9X4 :D
checking stability as we speak,
but I think I found a winner OC
CPU-Z Validator 3.1
Heres to hoping that its stable......
shit.
5 mins in and I get a the grey screen :S
Is OCCT still the best for stressing all CPU's or just Intel?
Anyone recommend a AMD specific stressing app?
I have it sitting now @ 3.7 x4.... stressing at around 40-43 under a H50
202x 18.5
Vcore: 1.435 in bios.
HTT 2200mhz
NB: 1.3V
Rams @ 1600mhz with really loose timings for the time being.
Below is a quick Everst Cache bench
CC-HotSpot Host
YouTube Instagram Twitter
Old December 10, 2009, 06:55 AM
geokilla's Avatar
I say stick with OCCT. Any update on your overclock?
Old December 10, 2009, 08:18 AM
mattlef's Avatar
I've gone and updated the bios to 0904, seems to help a bit in regards to stability.
I plan on throwing a shit load of volts at this chip to get to 4.0, but not with this board (M4A785TD-M Evo)
I'm gonna try to get this 3.7 clock stable. I'm hoping the sweet spot is around 1.46V
Man, this chip needs some serious volts.... its not stable @ 3.7 with 1.49V....
I'm gonna downclock to 3.6 and try focusing on tightening up the ram timings for now.... attack the clock when I get my new board.
I think I can get it stable in the mid 1.5*'s Vcore at 3.9-4..... but... I'm worried that I might ruin the chip.
I think I'll go for broke in a bit.... but once I have it stable, I'll drop back down to 3.6 for a 24/7 stable clock.
CC-HotSpot Host
Old December 10, 2009, 09:04 AM
Cowboy's Avatar
these phenoms are good for 1.55 volts. Some people even say its okay up until 1.6 if you on water. Anything above that and you should look at phase change or LN2.
Old December 17, 2009, 11:23 AM
Default re
Where did you pick that 1,6 volts is ok on watercooling system?
I am a little interested...
Old December 17, 2009, 11:31 AM
Perineum's Avatar
I run 1.475 to 1.525 volts with these chips. I get them unlocked to quad and running at 3.8ghz at that voltage, cooled by a Hyper 212+
I use two instances of Orthos to test stability, then when 24hr stable I use folding@home to double check.
Old December 17, 2009, 01:22 PM
I have myself an athlon2 x3 425(it dont unlock) running at 3.7ghz with 1.6v in load, never pass 43c temp and folding 24/7 for a month without any problem
Old December 17, 2009, 02:06 PM
Still, unlocking 2 extra cores and getting a pretty decent overclock is hawt for a chip that's barely more than 100$.
Old December 17, 2009, 02:20 PM
Caldezar's Avatar
My X2 550 runs well at 3.8 with 1.5v. I never saw an issue with it, but I clocked it down to 3.5 and lowered the voltage since this CPU doesn't seem to want to display it's temp with any monitor I use.
Old December 17, 2009, 04:53 PM
Kayen's Avatar
Try OCing it on the new board yet ?
550 BE unlocked jay51 CPU's and Motherboards 6 December 8, 2009 11:12 AM
My $550 Build- Please check it out!!! jcmaz New Builds 4 October 7, 2009 07:21 PM
Phenom II 550 jcmaz CPU's and Motherboards 2 October 3, 2009 07:56 PM
AMD 550 unlocked to B50 X4 OC @ 3.7GHz 1.415v canmx120 Overclocking, Tweaking and Benchmarking 9 October 2, 2009 08:50 PM
