Old December 2, 2009, 07:15 PM
vagnaar's Avatar
Default i7 4ghz :D
Hey everyone!
I finally got all my parts from Bestdirect!
After many hours of fiddling here is my overclock to 4ghz!!! also my ram to 1600mhz
my parts:
i7 920 D0
Corsair h50 liquid cooler (push/pull with 2 coolermaster R4 green led fans)
OCZ platinum 6gb ddr3 1333 7-7-7-20
EVGA X58 le
Corsair HX850 psu
4870 512mb
Silverstone Raven RV02
Temps seem pretty good, tell me what you guys think :D
Also ill get pics of the whole setup asap!
Old December 2, 2009, 07:17 PM
Arinoth's Avatar
Idle temps don't mean anything neither does the OC unless it has been proven to be stable using Prime95, OCCT, etc, which stresses the cpu/OC to see if its stable at full load for hours (4 hours min but others will claim 10 hours to really claim its stable).
Here I am: here I remain
Old December 2, 2009, 07:19 PM
Pike's Avatar
Nice...now, where are my parts?
"It is no measure of health to be well adjusted to a profoundly sick society" - J. Krishnamurti
E8400@3.0Ghz - Gigabyte EP45 UD3L - OCZ 4GB PC2-8500 DDR2 - Sapphire 5750 512MB - 5 Seagate HD 500GB - Plextor 712A DVD-RW - CM HAF 922
Originally Posted by Arinoth View Post
Idle temps don't mean anything neither does the OC unless it has been proven to be stable using Prime95, OCCT, etc, which stresses the cpu/OC to see if its stable at full load.
Bingo.
Old December 2, 2009, 07:21 PM
vagnaar's Avatar
I did run some hyper pi just for an average test, and i ran prime95 but what it the best way to configure it? the load temps were with prime95 Blend test.
Old December 2, 2009, 07:28 PM
Arinoth's Avatar
How long were you running prime95 for?
Old December 2, 2009, 07:32 PM
You should use small FFTs in Prime95 to stress your CPU. Blend is primarily for testing RAM stability. And OCCT/Linpack/IntelBurnTest/LinX is a better stress-test than Prime95 anyway.
Old December 2, 2009, 07:43 PM
vagnaar's Avatar
ok running intelburntest now
Old December 2, 2009, 07:52 PM
gingerbee's Avatar
nice clocks
Old December 2, 2009, 08:42 PM
Silvgearx's Avatar
thats not 4ghz
OC'ing q9550 past 3.4ghz ricknash61 Overclocking, Tweaking and Benchmarking 6 October 14, 2009 05:52 PM
P6T i7 920 3.4GHz??? sinticfury Overclocking, Tweaking and Benchmarking 3 August 20, 2009 07:57 PM
OC E7200 from 3.73Ghz to 4Ghz geokilla Overclocking, Tweaking and Benchmarking 1 May 3, 2009 01:04 PM
The Magic 4GHz NyteOwl Overclocking, Tweaking and Benchmarking 15 September 8, 2008 06:46 PM
4Ghz Q6600 Prime stable turtletrax CPU's and Motherboards 14 August 13, 2007 10:05 AM
