Old December 2, 2009, 08:46 PM
vagnaar's Avatar
having a weird problem now
any time i try to overclock my bios only shows 4gb or the 6gb of ram i have, but if i turn of the pc form the psu and turn it back on it will show up. This is so strange, anyone have any ideas?
i also just upgraded firmware on the mobo but it did it before too :S
Old December 2, 2009, 08:54 PM
Arinoth's Avatar
Bios updates sometimes break stuff that previously wasn't broken. The latest bios update may screw up with the amount of your specific ram you have installed while other versions may not. I never update a bios if i have a stable oc as it tends to break it.
Here I am: here I remain
Old December 2, 2009, 09:12 PM
vagnaar's Avatar
Well its the reason i updated the bios, was because sometimes 6gb would show up and sometimes 4 would, it's very strange :/
Old December 3, 2009, 12:09 AM
rjbarker's Avatar
Seems the claim to 1333 RAM running at 1600 Mhx just hit its first speed bump......you've got anomalies because your not stable.
With that RAM OC'd that much, I'll bet dollars to doughnuts you won't ge thru LinX 20 passes Max Memory tested without erroring out. Maybe yu will, but I doubt it...first you have to get your Rig to "see it" all!!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old December 3, 2009, 01:53 AM
why did you buy an i7 but turned hyper threading off..... Mind as well have gone for an i5 750 as it's the same thing..
Old December 3, 2009, 08:38 AM
vagnaar's Avatar
the memory thing happens even if i put it at stock settings 1333mhz, its a very strange error that i've read online. I'm looking more into it. If i clear the CMOS it's fine, but the second i change one setting in the bios POW only 4gb instead of 6gb :( guess i better fiddle some more.
Old December 4, 2009, 09:50 AM
kiwik's Avatar
Where's the Hyperthreading?
Old December 4, 2009, 06:37 PM
vagnaar's Avatar
I'm just playing with it yet, its my first intel proc since my Pentium III 866mhz, so i'm still learning all its ins and outs :)
  #19 (permalink)
Old January 16, 2010, 01:41 PM
ur TEMP and vcore are awsome !. Mine running abit hotter to get 100% stable @ 4.0ghz.
OC'ing q9550 past 3.4ghz ricknash61 Overclocking, Tweaking and Benchmarking 6 October 14, 2009 05:52 PM
P6T i7 920 3.4GHz??? sinticfury Overclocking, Tweaking and Benchmarking 3 August 20, 2009 07:57 PM
OC E7200 from 3.73Ghz to 4Ghz geokilla Overclocking, Tweaking and Benchmarking 1 May 3, 2009 01:04 PM
The Magic 4GHz NyteOwl Overclocking, Tweaking and Benchmarking 15 September 8, 2008 06:46 PM
4Ghz Q6600 Prime stable turtletrax CPU's and Motherboards 14 August 13, 2007 10:05 AM
