  #21 (permalink)
Old November 27, 2009, 12:07 PM
somecanadianguy's Avatar
Not sure about your OC problem...
Post your full BIOS settings and you may get more help.
For screenshots in Win7 use the Snipping Tool!
To host images... why not upload them here?
  #22 (permalink)
Old November 27, 2009, 12:09 PM
Fudd Rucker's Avatar
Originally Posted by FiXT View Post
Hey Check it out - ImageShack® - Image Hosting - You can find great ways of shrinking your images right by use the "resize image" feature - WOW! Free for you to use now, resize to any of the predetermined options or customize it - FREE! - WOW!
Look now - FREE - WOW! ImageShack® - Image Hosting
Im well aware that imageshack has resizing. I just didnt bother cause i didnt know everyone would get thier panties in such a bunch over a pic, now the one you put up thats been resized cant be made out unless you zoom in 200%.
I couldnt think of something snarky or interesting to put here this time around.
  #23 (permalink)
Old November 27, 2009, 12:17 PM
Just checked and both are plugged in properly.
  #24 (permalink)
Old November 27, 2009, 01:29 PM
So I just got back from the grocery store and thought I'd give it a go again. Somehow it is now stable at 180 BCLK on 1.325V. No idea why.
Ran OCCT for 20m test and its fine, temp reaching around 48c at full load. Is that too hot or just fine?
  #25 (permalink)
Old November 27, 2009, 01:38 PM
BobbyLou's Avatar
Originally Posted by mattlef View Post
So to be sure, your chip is not responding to any voltage increases at all?
try 180blck @1.42, if it posts, up the blck untill it doesnt post.... go back to where it did post and run OCCT to check for stability.
try upping your ram voltages to 1.9 instead of the 2.1 I had recommended before.... It could be the ram needs more volts to run at the speed we're asking it.
maybe if he wants to melt something
Try turning Load Line Calibration on (vdroop control)
It lets me run my 750 20x Multi 200 blk
1.32Vcore
my temps never go over 60C (same cooler as you)
You possibly also just got a bad chip. Try selling it on here, or returning it the place you bought it from if you rly want a nice OC.
  #26 (permalink)
Old November 27, 2009, 02:51 PM
gingerbee's Avatar
Originally Posted by MarkOne View Post
wow it's nice, and faster than open Photoshop
ya jimbotoronto turned me on to it like 10 years ago and it's just gotten better over the years great free app
  #27 (permalink)
Old November 27, 2009, 03:02 PM
FiXT's Avatar
Hall of Fame
Sorry my post was more meant to reflect the idea of a spam post pimping out an offsite webiste - lost in poor translation - and your right I did do the image wrong. Fixed it.
For me an many others not using a 24inch screen - 1920x1200 throws off not just your post, but the whole forum page - hence the reason why such enormous photos are usually not well received. Its much easier if you crop, or just use the imageshack image thumbnail tool
I also have learned to really like Picasa Web Albums as a quick online photo editor & hoster
  #28 (permalink)
Old November 27, 2009, 03:05 PM
gingerbee's Avatar
I don't know much about the i5's but could it be something to do with the memory controller on the chip? just a thought not try to confuse you more
I5 750 vs. Phenom II 955 bumfloss New Builds 13 December 11, 2009 12:15 PM
TRUE 120 and i5 750 Sleal Air Cooling 4 October 19, 2009 06:21 AM
i5 750 Build Help bumfloss New Builds 20 September 14, 2009 04:57 PM
