-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   questions on overclocking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/25776-questions-overclocking.html)
slovakftw November 22, 2009 05:23 PM
2 Attachment(s)
new to overclocking more then a couple of mhz
Should my FSB:DRAM be 1:2?
Do all these settings look fine?
How much higher could i go?
Zero82z November 22, 2009 06:42 PM
If you want to get the most out of your CPU, you should set your FSB:DRAM ratio to 1:1. That will help you reach higher FSB speeds. Once you find your max CPU overclock, then you can play around with raising your RAM speed.
