Old November 12, 2009, 08:08 AM
Default Gigabyte GA-P35DS3l Overclocking help
Hey guys I have been running into this weird problem with my gigabyte board recently. It will not keep my FSB setting when I try to overclock. I have an e6550 and I have had it at 3.0GHz before but it does not want to keep the setting anymore and reverts back to stock FSB. Is there anyway to fix this?
Old November 12, 2009, 10:47 AM
3.0charlie's Avatar
Reset the CMOS.
Hydro-Quebec is salivating...
Old November 12, 2009, 11:06 AM
SugarJ's Avatar
But first take the battery out and disconnect the power supply for at least 15 minutes. I had this problem with my board as well.
Old November 12, 2009, 01:54 PM
Alright thanks, I hope this works I will try it when i get back from class. Just for clarification does taking the CMOS battery out and disconnecting the power supply reset the CMOS or will i still have to after?
Old November 12, 2009, 02:49 PM
It will (or should) reset your BIOS settings, so you will need to re set all of them after.
Old November 12, 2009, 02:51 PM
geokilla's Avatar
Have you tried updating the BIOS? Maybe you got a FSB hole?
Old November 12, 2009, 03:24 PM
SugarJ's Avatar
It's a known issue with that board. I've had it happen to me a couple of times. And yes, clear the CMOS after disconnecting the battery and PSU. It worked for me.
Old November 12, 2009, 04:07 PM
Thanks a bunch guys I am home now so I will let you all know if it is working when I do it
Gigabyte Overclocking Championship 2009 - Worldwide Finals! FiXT Overclocking, Tweaking and Benchmarking 5 June 3, 2009 08:03 AM
Overclocking Using GigaByte Easy Tune 6 DaKine Overclocking, Tweaking and Benchmarking 7 April 13, 2009 01:27 PM
GIGABYTE Open Overclocking Championship (GO OC 2008) MAC Press Releases & Tech News 17 September 24, 2008 09:02 AM
Gigabyte Launches Overclocking Contest Shadowmeph Press Releases & Tech News 4 December 21, 2007 12:39 PM
Problems Overclocking with Gigabyte GA-P35-DS3L DukeNukem Overclocking, Tweaking and Benchmarking 8 December 13, 2007 05:35 PM
