Old November 15, 2009, 04:18 PM
Hey guys,
Tried SCG's settings but still getting the same error (fail on pass #1 LinX; 1024 MiB test) -> positive normal residual w/o BSOD.
Anything else I should be looking at?
Old November 15, 2009, 04:25 PM
Do you have CPU and RAM clock skews? On my ASUS R2E I have to put ~200ps delay on both.
heatware
Old November 15, 2009, 04:48 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Well mine is the P55 version so that could be the difference.
Originally Posted by somecanadianguy View Post
Hmm... do I have the only motherboard that isn't like that?
My Vcore always drops under load whether LLC is on or off.
Old November 15, 2009, 05:18 PM
Did you at any time in the past put Memory voltage at auto and tried to run memory at 1600? I tried it once shortly, and the memory voltage was set auto at 1.71v, way higher than the recommended max of 1.65v. I shut it down at once (after running P95 for about 10 minutes) and fortunately did not sustain any damage to my memroy controller.
Old November 15, 2009, 05:34 PM
Eldonko's Avatar
If you leave it on auto it will scale with VTT. Set it manually.
Old November 15, 2009, 05:40 PM
Hey guys, Thanks kindly for the replies!
@zoob - Skew is available to be adjusted, but I do not know how to appropriately adjust and test this parameter. Any advice on this from your experience would be appreciated!
@chris - I have always kept the VDimm within 0.45V of VTT
Re: LLC on vs off, here are the results on my computer LLC on - 1.28125V target; 1.248V idle; 1.232V load (-0.26V; 21% droop under load) LLC off - 1.36875V target; 1.312V idle; 1.280V load (-0.32V; 24% droop under load) I realize that I didn't use the same target voltages so this may be skewed, but given this data, is it suggested I leave LLC on or off (I realize my BIOS voltage will need to be set higher with LLC disabled). Thanks again!
Old November 15, 2009, 05:59 PM
somecanadianguy's Avatar
What OS are you running?
If it's 64bit make sure it's set accordingly in BIOS (your board should have that setting).
I've heard a couple people say that caused problems with linX.
Can you run Prime 95 Blend test OC'd with no problems?
Have you tried to run linX @ stock settings?
Maybe reset CMOS and then load optimized defaults.
Then see if linX gives the same errors @ stock..
Then try your OC again, but don't load it from a saved profile... input all settings manually again.
As for clock skew...
I don't really have any suggestions.
I've not had to mess with it yet.
Check out this link for a bit of info.
I've had trouble finding good info on clock skew and i7.
How to: Clock Skew Can Save Your Overclock And Memory - Overclock.net - Overclocking.net
Old November 15, 2009, 11:47 PM
Windows 7 64-bit Ultimate
HPET timer is set to 64 bit in BIOS
Prime 95 blend fails within 5 seconds at 17x uncore (@ 200MHz BCLK)
Will run stress tests on stock settings tonight.
  #19 (permalink)
Old November 16, 2009, 08:31 AM
Did you try a ram speed just below 1600, i.e.,1520.
cpu 190*20=3800
ram 8*190=1520
Sometimes these rams just do not meet the spec. I had to run mine at 1520 and was stable until I rma them to this new set I have now. 1520 is not that far off from 1600.
  #20 (permalink)
Old November 16, 2009, 01:31 PM
Can you post all your RAM settings from BIOS?
Going to jump in: i7 upgrade suggestions appreciated chrisk New Builds 90 November 30, 2009 04:20 PM
Gratuities Are Appreciated Arinoth Off Topic 3 July 18, 2009 03:36 PM
i7 Gaming/Office - Feedback Appreciated rbird New Builds 12 June 30, 2009 03:48 PM
build advice appreciated Hreidmar New Builds 7 October 15, 2008 03:59 PM
Oh Crap... input appreciated... TwystedMonkey O/S's, Drivers & General Software 3 August 2, 2008 10:26 AM
