Old September 11, 2007, 08:58 AM
Default need input
Intel Core 2 Quad Q6600 Quad Core Processor LGA775
ASUS P5K-E/WIFI-AP ATX LGA775 P35 DDR2 1333FSB 2PCI-E16 3PCI 2PCI-E1 SATA2
Ocz Platinum Xtc REV.2 PC2-6400 2GB 2X1GB DDR2-800
Are there any problems running this ram on the that board. Does anyone know
intel 960@4560 mhz giga ex58 ud5p
g-skill 12gig 1600 @1736 8-8-8-20 1t 1.6v
swiftech gtz waterblock
dual serial 655 pump
240 feser/360feser rads
diamond 4870x2 ek fullcover block 38c idle
2.29 tb hds
dual pioneer dvd burners
25.5 asus lcd
mountain mod case
12x120 mm fans
corsair 1000w
Old September 11, 2007, 11:46 AM
Patriote's Avatar
Never heard of any! Good choice BTW. Do you plan on overclocking ?
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old September 11, 2007, 12:54 PM
Default o/c
always.......... don't use water unless u push it but had a change, decided to get the e6850 should get that up to 3800mhz
2.29 tb hds
25.5 asus lcd
mountain mod case
12x120 mm fans
corsair 1000w
Old September 11, 2007, 02:45 PM
JD JD is offline
I'd go with the Mushkin HP2 RAM. It uses Micron chips so you'll probably get better overclocks from it.
Old September 11, 2007, 03:34 PM
Misoprostol
Guest
Posts: n/a
OCZ Platinum is not a premium SKU from them anymore. The old Plat. Rev. 2 DDR stuff was awesome, but DDR2 OCZ platinum (in my experience with it) has very little overclocking headroom...
Any input on all the new sound card Creative just launched? Misoprostol Audio 5 March 30, 2007 01:59 AM
