Alright so i have my e6600 running at 3.3ghz with 1.4v and according to coretemp my temps are hovering around 54 degrees and I have just installed a Sunbeam Tuniq with AS5 paste.. Now is it me or are these temps considerably high for this type of a overclock? I'm thinking of pulling the heatsink and cpu and lapping them both to make sure for flatness.
If thats idle temps then its a bit high. If its load then thats perfectly fine. About what mine does. If you lapped the CPU and heastsink you'd definately see some nice results. The C2D IHS is quite curved so it would surely benefit from lapping.
__________________ Xeon Quad X3350 | 3.40GHz (Damn X38 chipset) ASUS Maximus Formula | BIOS RF0410 2GB Corsair Dominator | 850MHz 4-4-4-12-2T 2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T HIS ICEQ4 Turbo HD4850 @ 700/1200 X-Fi XtremeMusic Antec TruePower Quattro 850W Antec 900 [ HEATWARE ] |
| Yah thats idle and I thought its a bit high. I'll be replacing the fan from the tuniq as soon as I figure out my damn power supply problems :(
E6600 here as well and im Oc'd to 3.4ghz.... idle temps are 38/34...... 54 is what my GPu's are iding at...... good luck with it... let us know if the temps go down..
__________________ E6600 Dual Core @3.4GHZ (1511 FSB) / 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / Corsair XMS2 TWIN2X2048-6400C4 2GB 2X1GB PC6400 DDR2-800 CL 4-4-4-12 680I SLI LGA775 MOBO / Samsung DVD+RW / Enermax Galaxy 1000 wats PSU / 24" Samsung CinkMaster Cooling: Swiftech Dual rad Swiftech Single rad Swiftech Micro Res Swiftech Apogee GT Cpu block 2x Koolance 8800 GTX Full Coverage Water blocks Feser One Blue Fluid |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lapping my E6600 | CanadaRox | Worklog | 19 | March 10, 2008 10:03 AM |
| Help overclocking E6600 on Asus P5KC | Jamz | Troubleshooting | 0 | December 14, 2007 08:49 AM |
| E6600 overclocking on P5B standard | Cenobite | Overclocking, Tweaking and Benchmarking | 16 | September 15, 2007 06:33 PM |
| Overclocking E6600, weird results | dosmond | Overclocking, Tweaking and Benchmarking | 4 | June 24, 2007 11:12 AM |
| e6600 p5b help plz... | razor4life | CPU's and Motherboards | 14 | April 7, 2007 01:32 AM |
