Old November 6, 2009, 09:14 AM
martin_metal_88's Avatar
Default I7 860
Hey guys, would like to know how many of you have a 860 from witch batch and the higher they can get stable. For me it a L925B478T batch and 3.8 is almost the higher stable. All over this it will fail prime after few second.
Thx a lot
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old November 6, 2009, 09:28 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Mine is the same thus far, but I am still working on it. I can do 3.8 with low voltage (ran 8 hours OCCT last night) but above that something is throwing me instability. Memory related I think, will report back when I figure it out.
Old November 6, 2009, 09:31 AM
Yeah same thing for me after 11hour prime core 5+6(HT) stop working. I am looking for memory me to but I don;t think this is the issue. I have 1600Mhz trident and she can boot over 2000Mhz in 2 click. Well, I carry on my side to waiting if one of us can find something interesting.
Ask for more
Martin_metal_88
Old November 6, 2009, 09:33 AM
Eldonko's Avatar
drop your multi and retest and you will know if its mem/VTT issue or CPU.
Old November 6, 2009, 09:34 AM
i got mine to 4.1 any higher its just too hot for megahalems to handle while priming
taking ht off cuts another 10c off temps
i think most 860s should do 4.0
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old November 6, 2009, 09:37 AM
Mine is now pretyt hot under a NH-U12P but the 1156 mouting kit is coming from Sidewinder computer should arrive next week will see if that can do better to.
Ask for more
Martin_metal_88
i7 860 build Eldonko Case Mods, Worklog & Gallery 23 November 9, 2009 07:32 AM
Need help with new mobo for 860 muffler New Builds 14 October 15, 2009 10:40 PM
noob help for i7-860 OC Sandro_Bit Overclocking, Tweaking and Benchmarking 2 September 24, 2009 01:40 PM
my i7 860 Build Sandro_Bit New Builds 5 September 11, 2009 10:34 AM
new i7 860 MOBO advice Sandro_Bit CPU's and Motherboards 27 September 5, 2009 06:25 AM
