  #21 (permalink)
Old November 10, 2009, 12:53 AM
HaDeS
Guest
Posts: n/a
some memory modules just don't like it others do. I've noticed in my overclocking stints the OC seems to be more stable when I make sure the ram is not running past it's spec. If your ram is 1066mhz stock staying below that will help. If your ram was 800 your computer will have a better chance of booting up running at or below 800mhz.
This is why people buy low volt ram... it gives them the head room to overclock the ram along with the CPU to achieve higher OC's. It's just a matter of finding the sweet spot but don't give up it's fun to do. :) I picked up the 1200mhz ram for my phenom which gives me heaps more options for a stable OC.
having issues with clocking i7 920 ToXic CPU's and Motherboards 13 August 27, 2009 07:56 PM
clocking 4870 x2 ToXic Video Cards 3 August 22, 2009 01:40 AM
4870 1GB clocking cadaveca Video Cards 21 February 17, 2009 03:03 PM
Over Clocking Ram mattydies Overclocking, Tweaking and Benchmarking 12 January 19, 2008 03:59 PM
e6600 Over clocking limit? mattydies Overclocking, Tweaking and Benchmarking 12 December 21, 2007 01:03 PM
