Old November 3, 2009, 02:27 PM
somecanadianguy's Avatar
Default Athlon II x4 620 + GA-MA785GMT-UD2H + ?
Well, the new budget build is up and running.
Would have taken pics, but my camera is 'in the shop'.
Sure wish I could have gotten more, but the budget was only $400 - $500.
I'd say I did pretty good with what I had... and the gf is really happy...
AMD Athlon II X4 620
Gigabyte GA-MA785GMT-UD2H
Crucial Ballistix 2x2GB DDR3-1333
WD Caviar Black 500GB
Corsair CMPSU400W
LG 22x DVDRW
CM Elite 330
Using onboard Radeon 4200 for now.
Hoping to get a good deal on a gts250 or something.
Would like to OC the CPU a little and need some tips.
Only have stock HSF atm so I don't want to push it too far.
Looking into getting a CM Hyper 212 or something soon...
Old November 3, 2009, 03:34 PM
headsh0t's Avatar
Cool man, let us know how far you can clock that CPU, well as far as you can with stock cooling I guess. I dunno what kinda of tips you need but if you got any questions just ask and someone will help.
Old November 3, 2009, 04:58 PM
Well I have never owned an AMD system so really don't know where to start.
Pretty much need to know some of the basics.
Old November 3, 2009, 10:43 PM
Fudd Rucker's Avatar
Ive built 3 HTPC systems this week with that same combo. For that purpose you cant find a better system for the dollar. My customers are tickled pink with thier new media center machines that were so cheap for the,
I couldnt think of something snarky or interesting to put here this time around.
Old November 4, 2009, 08:13 AM
Is there noone here OCing an AMD who can point me in the right direction?
From what I've gathered so far, I should be able to run around 3GHz on stock cooling.
This build darn near broke me so I just can't afford better cooling right now.
Max temp for the chip looks to be around 71c... at stock it gets 55c - 58c during Prime95 (according to Coretemp and AMD Overdrive).
Everest shows motherboard temp getting in the mid 60's, which I assume is because of the onboard graphics (but I don't know).
Should I bother wiping the thermal tape off the HSF and putting some MX-2 or something on it?
I've got some of that, and an unopened tube of the stuff that came with my TRUE.
Just left the tape on because I didn't have any alcohol to clean it properly.
Old November 4, 2009, 10:16 AM
gingerbee's Avatar
mx2 should be better then the tape. i can't help you overclock though because i have not overclocked any amd chips in a while sorry
Old November 4, 2009, 11:41 AM
Anyone with info/tips/links please post here and help me out.
If not... I guess I'll update this thread with whatever progress I can make.
It's not my computer (built it for my girlfriend) so I don't want to kill it yet... just make it sweat a little.
Hoping to be able to convince her to fold on it, but not sure about that.
If that happens I'll really want to get a half-decent OC going.
For now, I just want to push it a little... maybe 3 - 3.2GHz.
Old November 4, 2009, 07:39 PM
perhaps your case needs better airflow?
I noticed when I added some intake fans to my old system and upgraded the exhaust I had better temps.
Old November 5, 2009, 06:58 AM
Athlon II X4 620 OC to 3.2 GHz w/ stock cooling! - Overclock.net - Overclocking.net
Could be useful
Athlon II X4 620? somecanadianguy HardwareCanucks F@H Team 9 October 4, 2009 01:31 PM
L3 cache is unlockable on Athlon II X4 620, benchmarks galore Unknownm Press Releases & Tech News 0 August 27, 2009 02:15 PM
Corsair's 620 W 90% efficient PSU Babrbarossa Reviews & Articles from the Web 20 May 8, 2009 09:36 AM
HW 620 Dave510 Power Supplies 4 May 4, 2009 04:11 PM
