drenerk
Trial Member
Level: 1 - 1 points to level up
1st post: new i7 high end PC, overlocking question?
Hi there, this is my first post on Hardware canucks.
I have just ordered parts for a new high spec PC. I am going to want to overclock it and have never done so before. Could you guys help me out and tell me what I will need to do. Thanks a lot.
My computer spec.
- INTEL CORE I7 920 2.66GHZ (I will want to over clock as much as I can safely)
- EVGA X58 LE motherboard or i might get the - Asus P6T Motherboard
- ThermalTake Armor+case
- Thermaltake Armor+ water cooling (with i7 update)
- extra three 12mm case cooling fans
- CORSIAR SLI TX 750 WATT POWER SUPPLY
- BFG GeForce GTX 285 OC 1024MB GDDR3 SLI (x2)
- LITEON IHOS104-37 BLU-RAY AND DV
- SPOINT 1TB 7200 SATAII 32MB NC
- CORSAIR 12GB RAM 6X2GB DDR3
Thanks in advance
