-   Overclocking, Tweaking and Benchmarking (https://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Help Pushing AMD 955 Black Edition (https://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/24843-help-pushing-amd-955-black-edition.html)
Surfer_2099 October 26, 2009 07:24 PM
Hey there,
I've been messing with some numbers to try and see what I can squeeze out of my 955 Black Edition. I've got it installed on an MSI 790GX-G65 motherboard with Corsair XMS3 1333 Ram. The rest of the specs are in the signature below.
I tried running AMD Overdrive but it always hangs. The one time it almost worked it gave me some riddiculous number like FSB : 873 with a 4x Multiplier. I hung when I tried to apply just for kicks.
So... I've been doing it the old fashioned way using FSB and Multiplier but I have NOT touched the voltage. As it stands now, I have it at a rock solid 219 x 16.5 (3.622 in CPU-Z). I am able to run Prime95-64bit (4 cores) and FurMark stress test simultaneously for 24 hours. I end up with temps of 48 C on the CPU and 77 C on the video card.
I am however, unable to push it past this point with any stability. I can lower the FSB and up the multiplier but once I get to 3.66 or so, I can run 3dMark06, but once I start running Prime95, I crash.
I tried pushing the FSB higher and lowering the Hyper multiplier (to keep it between 2000 and 2200) and lowered the Ram multiplier ratio to keep it under 1600 Mhz, but this causes posting issues.
So yeah... it's not like I am unsatisfied with 3.6 or anything, but I am just under 20k for 3dMark06 and I'd like to break that barrier.
Is the next step to start pushing the voltages or is my proc just at the limits of it's stability?
Does anyone have any experience with the MSI board I have and any suggestions on which voltages to push up and how much / increments. What about the upper limits of the XMS3 Ram I've got?
Stuff like that.
Cheers!
OC_Canuck :)
Fudd Rucker October 26, 2009 07:35 PM
mine did 4ghz on 1.5v stock fsb on a gigabyte udp4 ddr3 board no sweat. If you got the black edition id stick with just multi overclocking as i found little results on fsb oc unless your shooting for a higher memory clock.
sswilson October 26, 2009 07:51 PM
Mine (both of them... ;) ) reacted the same way as far as stock voltages go. 3.6 was rock solid at auto voltage settings.Definately time to start bumping up the CPU voltages.
geokilla October 26, 2009 07:55 PM
It's time to start playing with the voltages. I'd say it's safe to go up to around 1.45Vcore. Any higher than that then I'll start to worry a bit.
Correct me if I'm wrong, but I believe there's also NB overclocking for Phenom II.
Surfer_2099 October 26, 2009 08:09 PM
Yes, there is Northbridge OCing as well and I'll get to that once I solidify my CPU settings.
I guess I am going to see what I can do with the Voltages now... woot!
Cheers!
Warranties_Are_For_the_Weak_Canuck :)
Surfer_2099 October 27, 2009 09:00 AM
Ok... last night, when I went to be, I had tried quite a few configurations with some success, but without any Rock Solid -Prime95 like- stability.
My best result was 3.977 Mhz (215 x 18.5) running at 1.4 volts. The ram was 1405 Mhz (or so). I also upped the NB to 2400 in the BIOS.
With these settings, I was easily booted into Windows and was able to run FurBench and 3dMark06 successfully (score was around 20,700). I could launch programmes and browse HOWEVER if I ran a stability test (either in AMD Overdrive or Prime95), I would get a Blue Screen after about 20 seconds. The CPU temps were below 50 C for the 100% load that I could see.
Is it just not quite enough voltage? I hesitate to run it much higher than that. The big red numbers in my BIOS saying "Don't raise the voltage past 1.382" are freaking me out a bit.
Anyhow, I left the NB at 2400 and clocked the CPU back down to 215 x 17 = 3660 and brought the voltage back to 1.35 and it's able to run Prime95 again no problem.
Suggestions?
Testing_Canuck :)
sa seba October 28, 2009 11:54 PM
Up to 1.5 Volt should be safe even for long term.
HaDeS October 29, 2009 01:42 AM
You may have hit a memory hole... this happend to me on my 920. I couldnt get past 250fsb. So I went way past it and I was stable again with the voltage up. Try and keep your memory under the 1333 is spec'd for... this is where I lost stability... then slowly bump up your ram volts and increasing the ram speed again. I'm still pretty new to OCing but this is how I stablized my phenom II. I was able to get completely stable at 3.724 1.5 volts. 266fsb 14x multi. ram was 1157 or something.. just below 1200mhz
Here's my thread with some pics of the numbers... hope it helps a bit.
http://www.hardwarecanucks.com/forum...oc-3-7ghz.html
KaosMage October 29, 2009 06:18 AM
pump up that voltage you got the same possessor that i'm about to buy i wanna see what it can do:P
Silvgearx October 29, 2009 03:49 PM
Cheers!
Suggestions?
Testing_Canuck :)
bring up the voltage......
for 3.977mhz try
CPU 1.475
CPU NB VID +.100
HT link @ 2400mhz
NB +.100
err, Canuck out !
