Old October 24, 2009, 03:57 AM
Default Green Machine OC
Well, Here are some results of my oc so far. My last oc on this rig was with an e6400, 2G of OCZ 6400 and a freezone. My best stable clock was 3.4. I'm getting much better temps with the elite.
Old October 25, 2009, 02:33 PM
I am running prime95 stable at 3.6 for the last 10 hours. However, my vcore in bios is at 1.368. cpu-z is showing 1.29 and I don't want to push past the 1.36 intel specifies for this cpu. This voltage drop is killing me. I think I can push it farther. I was reading up on a pencil mod which will help with vdroop or vdrop or whatever it's called and I feel confident doing this. It's a mod for 680i and 780i chipsets. Has anyone here tried this mod? I would like to hear some suggestiuons either for or against it.
Thanks.
Old October 25, 2009, 03:44 PM
Babrbarossa's Avatar
I haven't used a 680i for quite a while, but if I recall correctly, there is really no advantage to overclocking by doing that mod other than calming your nerves a little while cranking up the juice. It would come in more handy for undervolting CPUs so you can accurately give it enough voltage to sustain load power requirements.
I suppose if you were getting to the max voltage settings in the bios, you could push it further by ensuring that the CPU was actually getting all the volts the board was capable of (as it went up in smoke)
Old October 25, 2009, 08:11 PM
That is exactly why I'm going to do this mod. It reduces your voltage drop-droop between your bios voltage and your windows (cpu-z) voltage. I haven't heard anything negative from anyone who tried this on an evga or xfx 780i. I'll get at this tomorrow and post results.
For anyone interested, here's the link to the mod.
680i (eVGA, XFX, BFG...) A1 / D00 Rev. VCORE AND VDROP DONE! - Page 5 - XtremeSystems Forums
Old October 26, 2009, 04:58 AM
I'm extremely happy with the results of this 2 minute pencil mod. Here are the results...
Before pencil mod @3.6
Voltage setting in bios: 1.381<<< 1.33 current
cpuz in windows: idle 1.33<<< with prime95 load 1.296
After pencil mod @3.6
Voltage seting in bios: 1.381<<<1.36 current
cpuz in windows: idle 1.36<<< with prime95 load 1.36
Looks like I'll be able to squeeze a little more out of my oc. I'll continue with updates.
Old October 26, 2009, 07:06 AM
Nice work- I just loaned my old 680i to a friend and it's coming up with memroy errors after trying a few types. Looks like the memory controller might be gone- I'm hoping that when I RMA it, they will give me a 780i in return...I've heard they're doing that now.
Old October 26, 2009, 08:33 AM
I'm now testing @3.7 (462X8)
voltage setting in bios: 1.337<<<1.32 current
cpuz in windows: 1.32<<<with prime95 load 1.328
I was able to boot into windows and start prime at 3.8 with this voltage but decided not to rush things. Prime95 has been running for an hour. I have to leave for work later and by the time i get home, It'll be a 13-14 hour run. If prime is still running when i get home, it's on to 3.8. Temps are steady at 31-32 idle and 51-52 load.
Project: Green Machine mo' power Case Mods, Worklog & Gallery 18 October 25, 2009 10:46 PM
Machine burnt out. New machine needed Neutronium New Builds 15 March 18, 2009 12:23 AM
Need a GREEN 5.25" LCD vulcan500rider Display Units 9 March 3, 2009 09:50 AM
More Green Machine "rumours".. rjbarker Rumor Mill 0 October 12, 2008 06:58 PM
Green Border/Color Changes Drader Video Cards 0 October 1, 2007 08:43 PM
