  #21 (permalink)
Old October 23, 2009, 09:28 PM
Dadi_oh's Avatar
If you are looking for one of the best "bang for your buck" coolers check out the OCZ Vendetta or Vendetta 2. I have 3 of them and the performance is within a degree of coolers costing 3 times as much. Highly recommended.
My Q9550 (basically 2 of your E8400's in one package) running at 3.8GHz and 1.224V on the core only barely goes over 50C with a Vendetta 2 (and Qfan is enabled so it isn't even full speed). With an E8400 you probably would be in the low 40's.
The Vendetta 2 can be found for $31 and the original Vendetta even cheaper (would run a few degrees hotter).
OCZ Vendetta 2 Triple Heatpipe CPU Heatsink AM2 LGA775 S939 S940 S754 120MM Fan 800-1500RPM 20-32DBA - DirectCanada
Rig1: Q9550 @3.8GHz Vendetta 2, P5Q-PRO, 6GB OCZ Reaper PC2-8500. 5870 1GB, GT240 Physx, Ultra LSP 750W, 2TB internal + 2TB external, 3X23" 5760X1080 eyefinity + GT240 Physx, HAF22 case 3X200mm : Win7 Pro
Rig2: E8200 @3.6GHz Vendetta HSF, DFI P45 LP-JR, 4GB 900MHz, 4870 512MB, X203W 20", Ultra Gladiator Case
Rig3: Q6600@ 3.5GHz H50, P5Q-PRO, 8GB, 8800GTS512, OCZ GameXStream 850W, Samsung 245BW 24" + 19" dual: Snow Leopard + Parallels Win7
Rig4: MAC mini Snow Leopard
Laptop: Macbook Pro 15"
  #22 (permalink)
Old October 25, 2009, 12:25 AM
BrianHanna's Avatar
this is what i've have running stable for the past 9 months.
god the e8400 is such a god damn beast!
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
  #23 (permalink)
Old October 25, 2009, 01:23 AM
bottle's Avatar
Might want to fix your TJMax there. It appears to be set at 95. You want it to be 100.
  #24 (permalink)
Old October 25, 2009, 05:45 AM
Default Real Test...
Why wont people save alot of time and run IntelBurntest.
If you Pass 5 cycles its Stable I run 20 To make sure...
OCCT = Fail of a test.
Prime= Fail of a test.
  #25 (permalink)
Old October 25, 2009, 02:23 PM
BrianHanna's Avatar
yea, i fixed that long ago. either way, i hear thats abnormally cool for that overclock.
4 Ghz stable(?) bkh2 Overclocking, Tweaking and Benchmarking 20 August 24, 2009 05:20 AM
I7 Stable @ 3.81 Ghz rjbarker Overclocking, Tweaking and Benchmarking 17 March 10, 2009 11:37 PM
2.84 GHZ on Q9450 CTA Overclocking, Tweaking and Benchmarking 42 October 25, 2008 11:11 AM
I need help getting my e8400 to 4.0 Ghz dopedave Overclocking, Tweaking and Benchmarking 11 July 8, 2008 09:38 PM
WTB: E8400 3.0 Ghz darksniperx Buy/Sell & Trade 0 March 6, 2008 06:18 AM
