Old October 20, 2009, 07:49 PM
MpG's Avatar
MpG MpG is offline
The GPU test in OCCT is messing you up? Last I heard, ATI's drivers automatically try to intervene whenever Furmark or OCCT's GPU test are used, that might have something to do with it. Aside from that, the creator of OCCT was recently working to boost the power draw for the GPU, to the point where the 4870's were being overdrawn. Since the 4870X2 is basically twice the amperage draw, but (I don't think so, anway) not twice the power circuits, the situation might be even worse.
Old October 20, 2009, 08:26 PM
Originally Posted by Chris View Post
I have your gigabyte mobo, ver 1.0 which is good for ddr3 2000+ memory. If you have the ver1.6 board, you are good for 2100 memory. So, looks like you are at the margin. I would just overclock the cpu first to make sure it is stable for the speed that you want. I use P95 and I run it overnight for 9-10 hours. I had the loadline calibration disabled. You can see my detailed settings, as well as a few others, in this thread:
Post your i7 920 (and stepping) OC
After you are happy with your cpu speed, cpu temp, fan speed and noise, etc. You can then slowly increase your memory speed to see how high you can go. If you have not done so, you can run memtest86+ to stress test your memory as its own to see if it can do 2000 at rated spec. BTW, I guess you already know the limit for vtt is 1.65v.
My past overclock experience is AMD64 4000+ on a DFI board. It was a lot of work compared to overclocking this i7 and gigabyte mobo. I find this really easy.
I've found the i7s alot harder to overclock than the S939 line due to the addition of more than 5 additional voltages.
Insane doom 3 case mod aviduser Off Topic 1 May 13, 2009 11:58 PM
gskill, patriot, intel, best for insane torrenting??? mishkin Storage 11 April 4, 2009 08:21 PM
HD4830 Insane budget card b1lk1 Video Cards 12 April 3, 2009 04:55 PM
Reno's Gaming Rig (Insane) renoracer Case Mods, Worklog & Gallery 45 September 16, 2008 10:34 PM
Yorkfield overclock on air! INSANE! Wankerfx Press Releases & Tech News 18 December 7, 2007 02:01 PM
