Closed Thread
Old October 19, 2009, 11:38 AM
Default Are these temperatures ok? what can I do to lower them?
I recently overclocked my Q6600 from the stock 2.4 GHz to 3.0 GHz, and am wondering what my temperatures SHOULD be. Here are my system specs:
Processor: Q6600 @ 3.0 GHz
Motherboard: nForce 680n LT SLI
RAM: OCZ Vista Ready 4GB DDR2 333 MHz
Graphics Card: GTX 260 MAXCORE 50 (216)
Heatsink/Fan: XigmaTeck HDT S1283
With an ambient room temperature of 19 celcius, it idles at 38. Running the Prime95 Torture Test (in place large FFT, max heat), it peaked at 65 celcius over 3 hours. I plan to run it longer tonight.
Will removing my fan and adding copius amounts of thermal paste lower the temperatures? Is there anything else I can do, other then get new cooling components? "Overclock" the fans?
Any help is appreciated, and if you have an overclocked Q660, feel free to post your rigs and temps for comparitive purposesm
Thanks,
Mike Trpcic
Closed Thread
Tags
cooling , fan , overclock , q6600 , temperature
Are these temperatures ok? what can I do to lower them? mtrpcic Overclocking, Tweaking and Benchmarking 3 October 19, 2009 12:53 PM
Q9550 Temperatures lKashl Troubleshooting 6 July 9, 2009 12:32 PM
What temperatures are your HDD? Silvgearx Storage 10 January 31, 2009 04:33 PM
How to measure temperatures? kav Overclocking, Tweaking and Benchmarking 4 November 19, 2008 07:17 PM
Accurate CPU temperatures? Below_Cost Overclocking, Tweaking and Benchmarking 8 February 6, 2008 03:17 PM
