Old October 19, 2009, 10:34 AM
Default Are these temperatures ok? what can I do to lower them?
I recently overclocked my Q6600 from the stock 2.4 GHz to 3.0 GHz, and am wondering what my temperatures SHOULD be. Here are my system specs:
Processor: Q6600 @ 3.0 GHz
Motherboard: nForce 680n LT SLI
RAM: OCZ Vista Ready 4GB DDR2 333 MHz
Graphics Card: GTX 260 MAXCORE 50 (216)
Heatsink/Fan: XigmaTeck HDT S1283
With an ambient room temperature of 19 celcius, it idles at 38. Running the Prime95 Torture Test (in place large FFT, max heat), it peaked at 65 celcius over 3 hours. I plan to run it longer tonight.
Will removing my fan and adding copius amounts of thermal paste lower the temperatures? Is there anything else I can do, other then get new cooling components? "Overclock" the fans?
Any help is appreciated, and if you have an overclocked Q660, feel free to post your rigs and temps for comparitive purposesm
Thanks,
Mike Trpcic
Old October 19, 2009, 11:37 AM
Adding more thermal paste will harm your temps, not help them. How are you monitoring them? You should be using either Real Temp or Core Temp. And 65C is a perfectly fine temperature for your chip, so you don't have to worry about anything. It does seem a little bit higher than normal, but you're still well within safe levels, and there's no risk of harming your CPU.
Old October 19, 2009, 11:49 AM
Sushi Warrior's Avatar
65 is 100% safe. Adding more thermal paste is BAD. You just want enough to cover the chip (a pea/rice sized drop) so you get the most cooler-IHS contact. Thermal paste is meant for filling the microscopic impurities in the heatspreader and CPU cooler base. And again, 65C is perfectly fine. As long as you keep it under 85-90C you will be 100% fine, and even then you're just being cautious.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old October 19, 2009, 11:53 AM
Yeah, your temps are perfectly safe.
Intel Core i7 920 4.1GHz w/ Thermalright U-120E
24GB G.Skill 1.25v DDR3-1600 9-9-9-24
eVGA 758 - A1
80GB Intel X25-M G2
1TB WD Black
1.5TB Seagate 7200.11 (still works!)
10.9TB RAID6 Samsung F4EG
XFX 5850 @ 1000/1250 w/ Scythe Setsugen
2X Dell U2412M Seasonic M12 850W
Q9550 Temperatures lKashl Troubleshooting 6 July 9, 2009 11:32 AM
What temperatures are your HDD? Silvgearx Storage 10 January 31, 2009 03:33 PM
How to measure temperatures? kav Overclocking, Tweaking and Benchmarking 4 November 19, 2008 06:17 PM
Accurate CPU temperatures? Below_Cost Overclocking, Tweaking and Benchmarking 8 February 6, 2008 02:17 PM
Q6600 Idle Temperatures zlojack CPU's and Motherboards 10 December 2, 2007 08:40 PM
