Originally Posted by geokilla AMD CPUs are not great overclockers? I laugh at that. They may not be great overclockers compared to the Core 2 and Core i5/i7 series, but you're still getting free performance. Plus 3.7Ghz on your Phenom II 920 is not easy to accomplish. |
Have you seen the Phenom I s ?
4ghz on a PH II are still uncommon
hopefully the revision of the PH II that are coming will do better.
Keep us posted Hades
i am impress that you can push a PH II that high on a nvidia chipset
