Old January 21, 2007, 12:16 AM
Babrbarossa's Avatar
Default 24/7 how much is too much?
I am now sitting stable at 3.3Ghz-- my temps are pretty good after i re-reseated my heatsink-- 40 idle, 52 load, but my voltage is at 1.41. I notice that most people with conroes these days seem to be sticking with stock voltages for their 24/7 overclocks. I can do 3.2 at stock-- In your opinons, oh esteemed coleagues, am I volting too high for that extra bit of torque?
Old January 21, 2007, 02:11 AM
Misoprostol
Guest
Posts: n/a
I personally would be perfectly comfortable with that voltage for 24/7 operation, as long as your temps are under 60C (by TAT) and you're priming for 24-48 hours without any issues.
Old January 21, 2007, 07:48 AM
great! ran two orthos' overnight and this morning they were still trucking and my load temp had actually gone down to 48 (using TAT)- when I shut them down it was idling at 39. Probably a combination of slightly lower ambient and the new seating getting worked in overnight-- very happy with it.
I think the newer 680i bios must have had a positive effect on overclocking too as claimed by evga-- at first, there was nothing I could do to get it over 3.2- Now at 1.45 I can run stable at 3.4 (but I think I'll stick with 3.3)
Old January 21, 2007, 10:09 AM
sswilson's Avatar
Stock on those is 1.3x isn't it?
If so, a bump of .1 (with decent temps) is probably not going to affect the longevity of the chip at all.
Once you start getting into .2+ you're probably starting to drop the lifespan down a little (what's a couple of years off of a cpu anywise.... most computers end up going to the dump with servicable cpus), and seems like .4+ is getting to the point where you're taking a chance of physical damage to the chip (some folks start reporting that their chips won't overclock any more).
It's still a chance you take no matter what extra voltage you use. That's why I prefer to stick with lower end chips that I won't shed a tear over if I have to replace them.... :)
Old January 21, 2007, 11:16 AM
Gav's Avatar
Gav Gav is offline
Administrator
If it decreases the cpu's life from says 10 years to 9 years I don't think it's to much of a sacrifice as i'm sure you will upgrade before it dies.:D
Old January 21, 2007, 12:16 PM
sswilson's Avatar
Exactly.
I've only had one cpu die on me, and that was because I was stupid enough to think that I could use the hsf without securing it properly to see if the board would post. (The hsf of course worked it's way off of the chip and it fried in less than 30 sec.... :) ).
Old January 21, 2007, 12:19 PM
Supergrover's Avatar
Exactly I got a old 2000+ XP @ 2000mhz thats been Folding 24/7 for years now, It gets upto 60c in the summer.
R.I.P.
Old January 22, 2007, 07:38 AM
Yeah-- and even if I did somehow fry it in a year or two, I would almost welcome the excuse to upgrade. SuperG-- do you fold with a team, or solo? Do you find it puts your power bill up?
Old January 22, 2007, 02:43 PM
I fold with a team, well I have been out of it for a couple of months, and yes your power bill will go up your running the folder @ 100% load so.... yeah I have my monitors setup to turnoff after 5 mins so that helps a bit.
You looking to get into the fold?
I would be more than willing to get a team going but we would need more ppl.
Got any questions getting setup go Here or hit me up.
R.I.P.
Old January 22, 2007, 03:47 PM
I am thinking about either setting up this system to fold at night, or my old athlon xp to fold all day. This rig would probably fold alot more in eight hours than the old one would in 24 though. I'm just not sure yet if it can be done with a 26.4 Kbps dialup connection-- is connection speed important?
And yeah, it would be nice to start a little folding team here, but I think it would be too little. Also- People like you are already doing it on their own teams.
Very nice FAQ on that link, btw.
