Old September 30, 2009, 01:41 PM
jumran's Avatar
Default OC Settings
This was my first attempt at OCing a system. After al lot of tweaks to the voltage I finally managed to get it stable at 4GHZ OC. My average load temps on Prime 95 were around 88 degrees Celsius which I know is a bit high but since normal apps and games would not push the CPU this much, would I be to ok run it at these settings 24/7 long-term without any damage? The following screenshot showing temps were taken after 8.5 hours of prime 95 blended stress test.
Systems Specs:
CPU- i7 920 D0
CPU Cooler- Noctua NH-U12P SE1366
Ram- Corasair Dominator 2 1600
PSU- Corasair HX750
Case- Cooler Master Storm Scout
Old September 30, 2009, 05:30 PM
Babrbarossa's Avatar
I would try it out for a while paying attention to the temps under everyday loads making sure that you're not regularly going over 70.
Old and New Settings WolfBane Overclocking, Tweaking and Benchmarking 51 February 28, 2009 08:23 PM
freezing at saving your settings..... rob123 O/S's, Drivers & General Software 3 October 12, 2008 01:58 PM
Ram settings JupiterTrooper RAM 5 September 16, 2008 05:36 PM
initial settings Jim CPU's and Motherboards 3 July 23, 2007 02:17 PM
Check your default HD settings sswilson Troubleshooting 5 July 7, 2007 05:37 PM
