Old September 30, 2009, 04:54 AM
Arinoth's Avatar
Default Odd Temps
I've noticed over the past week or so, especially last night, for some reason my temps are a good 5 degrees higher at full load then they used to be. I can't really think of what would make the difference if the ambient temperature "feels" the same as when i ran full load in my basement 5 degrees cooler (for the cpus).
What could be the culprit other then ambient temp, and remember i installed HSF back in august.
Here I am: here I remain
Old September 30, 2009, 05:13 AM
gingerbee's Avatar
get some digital gauges if you can they help a lot
Old September 30, 2009, 02:03 PM
somecanadianguy's Avatar
Got one sitting by my system.
Shows temp and humidity... only cost like $5.
Old September 30, 2009, 03:49 PM
Arinoth's Avatar
Sitting in your system, what for ambient temps or where exactly
Old September 30, 2009, 04:29 PM
Maybe I'm not talking about the same things as gingerbee.
The one I have is about the size of a small cell phone.
I have it sitting in my comp room to watch ambient temp/humidity.
Suppose you could put one inside the case, but you'd want a smaller one probably.
When was the last time you cleaned your case and fans?
Could also possibly be a furnace running now that the weather is getting cooler (ours messes with my temps quite a bit).
Old September 30, 2009, 07:56 PM
Arinoth's Avatar
Yeah though i have 4 case fans and 1 more HSF fan on the way now, plus i have better airflow when i'm in my room with the window/door open and stand fan blowing at the case.
Something very odd issamhay Troubleshooting 8 June 5, 2009 05:13 AM
E4600 odd temps Mr. Gruntsworthy CPU's and Motherboards 12 May 11, 2009 04:23 PM
Odd benchmarks Jonwall Overclocking, Tweaking and Benchmarking 5 February 8, 2009 09:43 PM
something odd Zippoh Storage 0 January 29, 2009 04:24 PM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
