Old September 28, 2009, 07:24 PM
lowfat's Avatar
Default what holds back high bclk?
I am having issues breaking 220 blck. 220 works great. 221blck will not post and results in a '6f' diagnostic error on my lcd. Now I've tried raising all my voltages damn near as high as they'll go and I still can't break this limitation. I've been told the CPU will go significantly higher than this as well. What voltages/settings help w/ a higher blck?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old September 28, 2009, 07:38 PM
sswilson's Avatar
Have you tried 225 in case it's a "hole"?
Old September 28, 2009, 07:55 PM
lowfat's Avatar
Yes. As well as 230, and a number in between.
Queen of Dreams WIP
Big Lian Li
Complete
Old September 28, 2009, 08:08 PM
MpG's Avatar
MpG MpG is offline
One consistent factor in all the high Bclk's really seems to be raising the PCI-E bus clock. Of course, if you raise it too high, you've got GPU and SATA stability to contend with. Wish I could vouch personally for that, but my own board will only go up to 102-103MHz w/o hardmodding, which is a common complaint about the board.
Old September 29, 2009, 04:28 AM
bojangles's Avatar
Yup try raising the PCI-E clock a little bit. Some people say it damages hardware, but doesn't overclocking anything do that lol? If that doesn't work, your CPU is already working at an amazing speed on air. Anything past 200 BCLK is an outstanding OC. DO you REALLY need to go any higher than 4.3 GHz?
Old September 29, 2009, 07:00 AM
Arinoth's Avatar
I am curious to hear about what your voltage settings are for your 4.3 OC on air
Here I am: here I remain
Old September 29, 2009, 07:04 AM
LionRed's Avatar
Probably need to do the hard mod to the MB. Usually the wall is at 222. Unless your MB is the 1.6 version (from what I understand). The hard mod enables you to up the PCI-e clock for getting past the 222bclk wall.
4.3Ghz is a very nice overclock for air.
What are your settings lowfat? All of em.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old September 29, 2009, 09:49 AM
lowfat's Avatar
Actually w/ the new CPU I've had it up to 4.6GHZ semi-stable But I'll be going under phase in the next few weeks, so I don't want to be limited by my board.
Interesting, so a hardmod will allow a higher PCIe clock but still not to get SATA/videocard boot issues? Do you have any more details on this. Next time I reboot I'll take some pictures of my bios' settings.
Queen of Dreams WIP
Big Lian Li
Complete
Old September 29, 2009, 12:13 PM
lowfat's Avatar
Are there any boards out there that will clock higher w/o the use of a hard mod? I am not a fan of soldering to tiny SMD's.
Queen of Dreams WIP
Big Lian Li
Complete
Old September 29, 2009, 02:12 PM
Arinoth's Avatar
Ah you have hyper threading off, something i want to try to keep enabled.
[FS] BNIB High End Radiator 240 TFC **High Performance** qaz393 Buy/Sell & Trade 4 August 17, 2009 01:47 PM
I am back from Peru! belgolas Off Topic 20 August 9, 2009 06:37 PM
eVGA X58, poor BCLK overclocking. lowfat CPU's and Motherboards 9 April 16, 2009 11:08 AM
I'm back and I'm stupid Babrbarossa HTPC Systems & Software 12 September 26, 2008 01:48 PM
Need some help and tips... for a desk thats holds my computer. MittWaffle Cases 9 March 22, 2007 03:15 AM
