Hi people, I have been wondering something with regards to my light overclock of A E6400 C2D. I have found the limits (2.84 GHZ) I can get with my Ram, It is the weakest link in terms of speed. Being DDR2 533MHZ running at a top speed of 710MHZ At 5,6,6,18 is as high as I get get. Anyways I have settled on a 2.4 GHZ speed for 24/7 use. When I plan on gaming for a bit I will bump it up to 2.75 GHZ for a stable speed with moderate volts to Ram and CPU. So my Question is, How long realistically will my Processor last with this kind of abuse?? The temps never get above 55C at load. I can't seem to get a solid answer on this. I hear "oh it won't last a year" or "It'll out last 5 years" Which is right? Should I just go back to default speeds when not gaming to help preserve life. I get the concept of as long as the temps aren't above 60-65C I should be fine for a long time. But also what about my Ram? Can budget Kingston handle 2.2 volts for a 6 hour haul?Please somebody help me sort this out. I am not rich so I need to be careful in how I treat my Rig
__________________ System spec: C2D E6400 3.1Ghz, EVGA 9800GTX 512Mb@800/2000/2300, G-Skill pc6400 DDR2 4*1 GB Sticks, ASUS P5B, Coolermaster 600 watt PSU,320 GB Sata, Acer 24 Widescreen, ATX 17 case, Zalman CNPS 9500 LED, Windows XP 32 Bit |
I don't think this will help, but I turn my Vcore down and overclock to 2600MHz (from 2400MHz).
__________________ **Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP |
Basically it is at 1.18 V.core which is way less than the default 1.35 V. Core at 2.13Ghz So I guess it'll hold out for a while till I can afford to buy a good Quad. Even at my max speed I didn't have to go above 1.4 V.core. Soon as I get some faster Ram things will change I'm sure. Thanx for the feedback
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| First Successful Overclock | vintank | Overclocking, Tweaking and Benchmarking | 15 | January 25, 2008 12:09 PM |
| Problems with overclock | FritzGuy | Overclocking, Tweaking and Benchmarking | 6 | December 10, 2007 07:14 PM |
| Help me Overclock my Firestix. | Dethredic | Overclocking, Tweaking and Benchmarking | 11 | November 9, 2007 10:15 AM |
| 8800 GTS 320 MB overclock | belgolas | Video Cards | 2 | September 21, 2007 06:52 PM |
