-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Q6600 Freakishly low vcore (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/23593-q6600-freakishly-low-vcore.html)
Digital_fx3 September 25, 2009 07:30 PM
I was just playing around with my q6600 G0
Just wanted to bump it up to 333x9 to checks it oc potential.
so it booted fine at 333x9 at stock vcore
I decided I will lower the vcore to find the min stable vcore for 333x9
I just hit 1.135 v (reported by CPU-z under 100% load) and 1 hr OCCT stable. haven't tried to lower it anymore, But am I right in thinking this is crazy low? After 1hr of occt temps are 59c on the STOCK cooler.
encorp September 25, 2009 07:43 PM
Yeah I've seen it, I had a Q6600 D0 with a very low vcore, I actually had mine run at 1.225v 4ghz! Oddly enough I noticed in order to go much more than that my memory would give out or I'd have to increase core voltage by leaps and bounds! it was odd!
geokilla September 25, 2009 07:47 PM
What's the VID? 1.135Vcore is really nice.
People over on AnandTech say that using CPU-Z to check Vcore isn't good, but I myself want to believe that CPU-Z is more accurate than just going with what the BIOS states.
Digital_fx3 September 25, 2009 08:41 PM
VID is 1.2125 I am curently testng 1.130 @ 333x9 (40 min so far so good) and get this....the MB is a Gigabyte G31M-ES2L. OCCT and cpuz both show the same Vcore.
P.S. If it makes any difference FYI I did lap the cpu down to 1200grit.
clone63 September 25, 2009 09:53 PM
At first I read 59C 1hr and thought "..." but then saw stock cooling, and that is quite impressive.
Lima September 25, 2009 10:42 PM
Shoot! This has got me curious to see how high it could go now.
gingerbee September 26, 2009 04:32 AM
I have a q6600 with the same vid and it will go all the way to 4.0ghz at the right voltage ( no over volting )
Digital_fx3 September 26, 2009 09:28 AM
Well I have a good feeling about this chip I would love to hit 4.0 in the 1.2xx vcore range. But I am sure I will be limited to the board. I will hunt for the fsb wall tonight but I am skeptical that I will get over 350fsb
it is a $60.00 board after all, So chances are I wont be breaking any records with it.
System specs
MB: Gigabyte G31M-ES2L
CPU: Q6600 G0
Ram: Patriot Blade ddr2-800 5-5-5-12 2x1024
PSU: Cooler Master 600 watt
GPU: Zotac 9800GT 1024MB (660 core 1800 ram 1650 shader) stock settings
HDD: Seagate 7200.12 500GB
Silvgearx September 26, 2009 04:58 PM
before you go any further. touch that little gold northbridge of yours.
Digital_fx3 September 26, 2009 07:05 PM
One step ahead of you. it is warm but not hot that is what I have been checking most often. However rather then push this board past 333 I will go out and pick up a board that is more inline with overclocking.
I will stick with gigabyte anyone want to recommend a decent one for around 150.00? Last one I had was a p35-ds3l and it was nice still wish I went for the DS3R tho.
