Old October 3, 2009, 07:14 PM
Just an update. I put a Cooler Master Hyper 212 plus on last night and decided to play some more to up the clock (Wanted to get to 3.6ghz) but getting the fsb over 345 seems futile even at lower multi tryed 6 and 7x. looks like the wall is much lower then I had hoped, However this cpu does hit 450x9 4050mhz with just 1.385 v on my striker Extreme 10hrs occt stable.
Maybe I am missing something to get the g31m-es2l to go to a 400mhz fsb?
Any advice would be helpful.
Old October 3, 2009, 10:06 PM
wow turns out this MB has the biggest FSB hole I have ever come across...from 341-419 lol boots fine @ 420x9 but then i have mem problems my crap Patriot blade ram maxes out at 835 so 840 is just too high.
and I hate messing with the ram timing...just a good excuse to go get some 1066 or better ram. but hey I have the board booting into windows at 3.78ghz @ 1.28 actual vcore! Too bad my ram falls flat on its face.
but a 78mhz fsb hole...non the less I am happy with the results..stupid ram it is always the part holding me back.
Old October 3, 2009, 10:15 PM
geokilla's Avatar
Wait, so you have a FSB hole from 341Mhz to 419Mhz? It's pretty common....Or was...
Have you tried updating to the latest BIOS?
Old October 3, 2009, 10:26 PM
yeah I have the newest bios f9c, I find it ironic because on the box it states 1600fsb (with oc) but the board is incapable of 1600mhz but it will do 1680+.
I know this isnt something many of you will get exited about. but if you consider the money spent. it is mildly impressive.
Old October 4, 2009, 12:59 PM
rai_polo's Avatar
I think that's pretty cool.. If you don't mind me asking. Is this a mATX build or did you just pick that mobo because it was cheap?
Old October 5, 2009, 08:37 PM
I had 60 in my pocket..it was an impulse buy and I wanted a home for my q6600 that has been sitting on the shelve for a while.
Old October 7, 2009, 04:46 PM
Right now I am sitting 100% stable (3 hrs OCCT 8 hrs prime 95) 393.8x9 1.32 vcore.
I did get a new board...I almost wish I didnt tho, I got a MSI P7N-SLI Platinum......the fsb has so many holes...I am pretty sure someone shot it a few times with a 12gauge, It takes forever to poke around the bios and find a fsb that isnt a hole lol. I hope to trade it for a p35-ds3r tonight or tomorow....750i is just poor for oc'ing quads.
Phenom II X2 550 -X4 Vcore max mattlef CPU's and Motherboards 3 August 29, 2009 05:20 PM
Scythe Shuriken Low Low-Profile CPU Cooler Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
Large Increase in vCore From 3.6 - 3.8Ghz rjbarker Overclocking, Tweaking and Benchmarking 17 April 9, 2008 09:14 AM
vcore fluctuations and oc magictorch Overclocking, Tweaking and Benchmarking 11 July 5, 2007 01:40 PM
I'm now confused Vcore real or not? Delavan Overclocking, Tweaking and Benchmarking 4 June 12, 2007 04:56 AM
