Old September 24, 2009, 12:23 PM
Sandro_Bit's Avatar
Default noob help for i7-860 OC
hey guys, any tips or tricks for a noob such as myself to get my i7-860 to a stable daily build. (nothing crazy, around 3.6ghz is decent for a decent oc right?)
specs:
EVGA P55 FTW MOBO
i7-860
8 gigs DDR3 Dual Channel Memory 1333mhz
Noctura SE2 Heatsink
thanks guys, i tried a 200x18 setup which worked fine but i'm not sure if i should be upping the voltage or tweaking the ram settings which worked fine, comp started no problems just looking for some advice on what to do next.
Old September 24, 2009, 12:59 PM
Make sure you Stress test that puppy, and Keep an eye on your temps.
Rig Specs:
EVGA x58 Classified Motherboard
Intel Xeon W3520 CPU @4.1 Ghz
6 GB (3x2GB) Corsair Dominator GT 2000 Mhz RAM
3 X XFX HD5870 XXX Edition Graphics Cards
Corsair HX1000w PSU
2 x Intel X25-M SSD's in RAID 0
3 x 2 TB WD Black HDD's for Files and Storage
2 x DVD Drives
Corsair H50 CPU cooler.
Old September 24, 2009, 01:40 PM
Sandro_Bit's Avatar
right now i have thee Dummy OC runing from EVGA until i get something reliable up.
Asetek LCLC or Corsair H50 for i7 860... Sandro_Bit Water Cooling 12 February 24, 2010 10:16 PM
my i7 860 Build Sandro_Bit New Builds 5 September 11, 2009 10:34 AM
new i7 860 MOBO advice Sandro_Bit CPU's and Motherboards 27 September 5, 2009 06:25 AM
Core i7-860 Tested: Faster than Core i7-920 Unknownm Press Releases & Tech News 28 August 30, 2009 03:05 PM
