Old September 18, 2009, 04:45 PM
HaDeS
Guest
Posts: n/a
Default Phenom 920
I'm just doing some overclocking and I don't have a ton of experience doing it... been outta the game for a long time now.
currently running the cpu at 235fsb stock volts 1.3ish If anyone has some tips or reccomendations i'm all ears
-cheers.
Old September 18, 2009, 07:31 PM
HaDeS
Guest
Posts: n/a
Ok well i've figured out rather quickly that I don't have many options with the multiplier as it's not unlocked on this cpu. That's fine I can deal with that. When my new ram shows up (rated to 1200mhz) I should beable to push the cpu another 3-5 hundred mhz giving me close to 1ghz more than spec. The current mushkin 800mhz ddr2 is the only thing holding me back at the moment... it won't boot when it gets past 800mhz. I've gained just over 2000 points in futuremark from overclocking... so far I'm happy.
Intel i7 920 or Phenom II 955? AmuseMe CPU's and Motherboards 30 August 13, 2009 06:00 PM
[FS] Phenom II 920 and M2R32-MVP Cheap! UrbKlr Buy/Sell & Trade 6 May 11, 2009 01:11 PM
[WTB] AMD Phenom II X4 920,940 or the 720 j-ronde Buy/Sell & Trade 0 April 21, 2009 12:20 PM
