Old September 12, 2009, 07:32 PM
WolfBane's Avatar
Default New attemt on a x3110 watercooled ????
Ok i got the bug and have been playing again :)
this is stable with prime for almost an hour:)
let me know what ya think ?
and check out the ram, can i go higher ???????
http://i29.tinypic.com/11wezy1.jpg
this is gskill ram F2-8000CL5-2GBPQ
NOW THIS IS THE 2 GIG STICK SO TIMES IT BY 2 I GUESS:)
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
Old September 13, 2009, 01:50 AM
bottle's Avatar
All I can say is holy low voltage and temperatures on that C0.
And as long as you keep the RAM within voltage spec, I think 2.2v? You can go further, but that could lower the life expectancy of the modules.
Old September 13, 2009, 03:05 AM
Jackquelegs's Avatar
Use a different FSB/Mem divider to keep the RAM in check. Usually DDR2-1000s will have about 50mhz-100mhz headroom, depending on the binning.
I would keep to 2.1v and lower for RAM voltage. 2.2 is normally not warranted.
Try to research about GTL ratios, they'll help quite a bit at higher clocks.
Iapetos
Zephyranthes
Old September 13, 2009, 07:37 AM
3.0charlie's Avatar
I agree! And once you try to go over 450 FSB, that Vcore will jump big time.
Good job!
Hydro-Quebec is salivating...
Old September 13, 2009, 08:37 AM
WolfBane's Avatar
Thankyou guys its always a work in progress but i agree i think that isn't to bad an OC for a 3110 :)
I USE EMT ONLY
Old September 13, 2009, 12:58 PM
Not at all. That's usually where it should be, and that voltage is excellent.
Iapetos
Zephyranthes
16 000 $ watercooled matsta31 Water Cooling 10 March 2, 2009 03:01 PM
[WTB] watercooled ati videocards. or 1 watercooled nvidia card kyle_L Buy/Sell & Trade 4 February 26, 2009 01:53 PM
x3110 second try WolfBane Overclocking, Tweaking and Benchmarking 9 November 20, 2008 11:45 PM
Does the X3110 run hotter then E8400? Dashock CPU's and Motherboards 36 August 15, 2008 11:14 AM
New Watercooled Setup cdn_Madrach Water Cooling 41 March 11, 2007 11:48 AM
