Old August 18, 2007, 08:52 AM
BALISTX's Avatar
Default Nvida nTune
I download Nvidia nTune to monitor temps on my computer. I noticed that it has the ability to run a session to determine the best overclock for your CPU and memory. Would anyone trust this to try it or do you think I will burn myself if I try it?
Heatware
HWBOT
Old August 18, 2007, 09:06 AM
sswilson's Avatar
I believe the word over on "the street" when I had my Ultra-D was to "absolutely not!!!!" use Ntune for auto OC on that board / chipset combination.
They didn't play nice together, but I don't remember if it was hardware or driver related....
I took that to heart and didn't use Ntune for anything other than checking temps.
How's the OC going so far?
Old August 18, 2007, 09:10 AM
BALISTX's Avatar
It's on hold till I get my aftermarket HSF I don't want to up the vcore until I get a better HSF. I'm running it stock for now to ensure it is stable enough.
Heatware
HWBOT
Old August 18, 2007, 09:30 AM
Supergrover's Avatar
I have used it on a Evga nf-41 Mobo, locked my system up everytime, well twice thats all it took :).
Havnt tried it since.
R.I.P.
Old August 18, 2007, 09:33 AM
BALISTX's Avatar
It was tempting to try and use it but as that old saying goes "Nothing in life that is worth doing is worth doing the easy way".
Heatware
HWBOT
Old August 18, 2007, 09:43 AM
When/what HS are you picking up? Think I read it inanother thread but cant remember. :(
R.I.P.
Old August 18, 2007, 10:18 AM
I have also heard on the street that Ntune is NOT THE SOFTWARE to use when trying to OVerclock and such. I did have it on my system, and I did create a profile for gaming. I ran the 3hr test to OC the system and such. The computer would lock up two minutes into the game after I had loaded the profile and tried to play.
I downloaded CORETEMP and I use that to monitor the CPU's.. and I use ATItool for the GPU temps...... but again this is just one mans opinon, and usually even that gets changed by my girlfriend!!!
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old August 18, 2007, 10:42 AM
BALISTX's Avatar
The Thermalright SI-128 with a Antec Tri-Cool 120mm RED LED fan. The fan is $12 and the stats on the fan are:
High 2000rpm - 79 CFM - 30dba
Medium: 1600rpm - 56 CFM - 28dba
Low: 1200rpm - 39 CFM - 25dba
Since I don't plan on using the fan control and have it on high I think those are pretty good stats.
Heatware
HWBOT
WTB Videocard ATI 3850/3870 or nvida 8800 genx Buy/Sell & Trade 0 January 22, 2008 08:26 AM
New NTune Released Today Babrbarossa Video Cards 3 January 17, 2007 12:36 PM
