I biult myslef a nice gaming rig for playing COD2. I basically only use the computer for doing this. I stay clear of most things and try to keep it clean and junk free. (I have a laptop for that). I have a mild OC on my system now. I did this by slowly increasing the FSB of the memory by increments of 40. The system would not boot at 1546, so I slowed everything down by 10's until I finished at 1506. Thats where I am at now. No voltage increases, no memory changes. The memory is UNLINKED.. I'm new to this, completely green and Im more of a hands on kinda tool maker, so this reading stuff is driving me nuts!! LOL. Orthos is giving me problems even at this OC. THe system runs fine, no lock ups, the game runs perfect as does 3DMark. Orthos run for 20minutes one time then the system locks up, the runs for 3 minutes the next.... but If I never downloaded and installed Orthos, I would have never been the wiser.... heres mmost fo the info that is running now..... thought this was the easiest way to share the info and make it clear for those who help... Not sure what Im trying to achieve here, guess I want a OC and a rock solid system... AND TO LEARN..... so if I end up at 3.6 that would be great too!!!! But if I stay where IM at, the all I ask if Orthos runs for 12 hours without locking up... http://pic18.picturetrail.com/VOL888.../271749192.jpg http://pic18.picturetrail.com/VOL888.../271749190.jpg http://pic18.picturetrail.com/VOL888.../271041222.jpg http://pic18.picturetrail.com/VOL888.../271041205.jpg http://pic18.picturetrail.com/VOL888.../271041207.jpg http://pic18.picturetrail.com/VOL888.../271041215.jpg just let me know if theres anymore info needed.... P.s. think in my sig it says memory running ar 4-4-4... dont think this is correct.. frosty
__________________ E6600 Dual Core @3.4GHZ (1511 FSB) / 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / Corsair XMS2 TWIN2X2048-6400C4 2GB 2X1GB PC6400 DDR2-800 CL 4-4-4-12 680I SLI LGA775 MOBO / Samsung DVD+RW / Enermax Galaxy 1000 wats PSU / 24" Samsung CinkMaster Cooling: Swiftech Dual rad Swiftech Single rad Swiftech Micro Res Swiftech Apogee GT Cpu block 2x Koolance 8800 GTX Full Coverage Water blocks Feser One Blue Fluid |
Hey, I have friends come over all the time and play COD2 at my place. I run it on all 6 of my systems without any problems at all. If your main concern is COD2, don't worry too much about OCing. Your system will chew up and spit out COD2 at stock!
__________________ INTEL Conroe E6700 EVGA NVIDIA 680i Rev A1 OCZ 2GB DDR2 PC2-6400 Platinum Revision 2 EVGA GEFORCE 8800GTX 2 x Western Digital Raptor 150GB ThermalTake TOUGHPOWER 750W (Modular) Silverstone TJ09 Black w/ window Thermalright 120 Ultra Extreme OCZ XTC Memory Airflow Cooler Logitech G15 Logitech MX518 Asus 18x SATA w/ Lightscribe 2 x Dell FPW2407 Rev A04 |
Since your board allows you to unlink, your first step should be to find a good unlinked setting for your memory. (Verify with memtest). You can then worry about finding max cpu OC without being concerned that your mem might be holding your back.
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
| Quote:
Isn't memory a whole new ball game when it comes to OVERCLOCKING???
| I guess yes to answer honestly.... thats all I really use the computer for... and I do agree the system does work wonders with the game. FIgured a good stable OC would benifit the speed and such.... increase FPS..... You know us guys..... never satisfied untill something's broke!! Maybe I should leave the system alone and try the GPU??
| Yep, that's why your first step should be to unlink it from FSB and set it to a stable stock speed so that you can focus on your CPU OC.
u have a guide handy on OC'ing memory??
Memory is pretty simple to OC.
__________________ Q6600@3.2ghz Asus P5N32-E Sli 4gb OCZ Platinum DDR2 @855hmz 4-4-4-12 2T Antec P180 Galaxy 8800GT. 700/2000/1800 Corsair HX-620 Thermaltake Power Express 250W Raptor150, WD 500gb. WD 300GB X-Fi Extreme Music |
so just to be clear... I increase 800 to 810, run Orthos for 30 minutes or so, then do that until Orthos fails??
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| The Build is off! Wife put the foot down | BALISTX | CPU's and Motherboards | 5 | May 3, 2007 06:28 PM |
