Old August 29, 2009, 10:40 AM
Unhappy core i7 950 OC problem
hello....
(my system specs are below in my signature)
Now i dont know that is my i7 950 D0 is bad batch or i am doing something wrong in overclocking.my Overclock is 10 hours prime95 stable @ 3.7GHz and the settings i used in bios are.
23x multiplier
BCLK 161
DRAMFrequency 1614 MHz
UCLK 3227 MHz
8-8-8-21
CPU volt 1.22
QPI 1.4
Dram volts 1.54
rest of everything is on AUTO and HT is also OFF /Turbo is also OFF
on these settings my i7 950 @ 3.7GHz is stable more then 10 hours in prime95 blend test and NO errors but when i try to overclock my cpu to 4 GHz its even not stable @ 1.33v
the settings i used for OC it to 4 GHz is same as above except Dram is running @ 1750 MHz and even its not stable if i run the ram @ 1450 MHz.even increasing / decresing Multi & Bclk is not stable @ 4ghz on 1.33v.so why my i7 950 requires such a high increase in CPUVTT from 3.7GHz to 4GHz.
3.7GHz stable on 1.22v while for 4GHz it take more then 1.33v.why is this?
CPU: Intel Core i7 950 @ 3.7GHz w/o HT 1.22v 24/7 * | Cpu Cooler: Thermaright 120 ULTRA Xtreme | Board: ASUS P6t6 WS Revolution | Mem: 6GB DDR3 G.Skills PC3 16000 Running @ 1600 MHz 8-8-8-21 @ 1.54v QPI @ 1.4 | GPU: Nvidia 3 x XFX GTX 260 Core 216 3-WAY SLI @ 700/1250/1431 (Core/Memory/Shader)
| HDD:- 640GB S-ATA Seagate Baracuda 32 Mb Cache 7200 Rpm | Cassing: NZXT Tempest *BIG TOWER*
PSU: Xigmatik NRP 1500 Watts
Old August 29, 2009, 11:11 AM
Babrbarossa's Avatar
Welcome to the forums- Starnge- My guess is that the CPU is just in the lower precentile of OCers- Have you made sure that your cooler is seated properly- what are your load temps?
Have you tried loosening the timings on the RAM to 9-9-9?
Old August 29, 2009, 11:27 AM
@ 3.7ghz load temps were 60-65C in all four cores with HT off and now i am trieing for 4 ghz and temps are 68-73C @ 1.34v and prime95 blend test is running.my idle temps are mostly 44-46C.yes i did tried ram @ 9-9-9.i think my cpu batch is shit
Old August 29, 2009, 11:45 AM
Dwayne's Avatar
Your DRAM volts seems a little low... are they rated for 1.65? Are they these? http://www.hardwarecanucks.com/forum...it-review.html
As Babs states, try setting the RAM to stock timings or use the XMP profile in BIOS. If they are the same RAM check the article to see how they did in testing.
Maybe you could up the Bclk and lower the multiplier? I am running a 920 with the following settings
vDroop Off in BIOS
vCore +.06875 (loaded it is 1.27 or 1.28)
ICH Core 1.1
QPI PLL 1.1
CPU PLL 1.83
IOH vCore 1.15
CPU VTT 1.25 (loaded it is 1.33 - 1.35)
DRAM 1.65
Bclk 200 X 19
RAM 1600
Uncore 3200
QPI Link 3600
My RAM is rated 7-8-7-20 at 1600 so that is what I am running.
Hope that helps.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
I want my Core i7 950 for $249.99 :D Mike_E Off Topic 3 August 28, 2009 01:28 PM
Hardware problem or HAL problem? andynerd Troubleshooting 1 March 7, 2009 09:03 PM
