Old August 12, 2007, 04:38 AM
Rapid-X's Avatar
Default Amd Tool
is there a tool i can use to overclock my amd 4800+ cpu. my board doesnt have the otion but i read a review on the same motherboard and cpu and they overclock the 2.5 to 2.85 ?? any ideas??
Old August 12, 2007, 06:02 AM
Rapid-X's Avatar
Default help!!!!!!!!!!!!!!!1
lol i tried clock gen and then when i restarted it worked great for like 4 hours now my computer starts up and restarts once the desktop is loaded .. any idea how to undo the cpu and ram changes by CLOCKGEN in safemode?? or even how to get back to normal im thinking if i pull my cpu power up and reinsert it will that hepl??
Old August 12, 2007, 06:31 AM
sswilson's Avatar
Nope.... the problem with clockgen if you set it to run @ startup is that it's hard to stop if you push too far.
I'm pretty sure it's run from registry so the only way around it is to edit the registry in some manner. (That's why I don't use clockgen.... I've had to reload a couple of times myself..... :) ).
Old August 12, 2007, 09:49 AM
Patriote's Avatar
Even if you find a tool that will let you overclock your CPU, it will probably just let you play with the FSB and not with the voltage... And with such CPU, voltage bumps are a must IMO.
You can try systool if you want to.
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
Old August 12, 2007, 10:59 AM
CMetaphor's Avatar
Quadfather
Start windows in safe mode... F8 ftw! lol. Then just remove it from your startup programs using Run -> msconfig
Old August 12, 2007, 11:07 AM
Supergrover's Avatar
Yup that should do it, isnt there a hotkey to return the clocks to stock? Played with clockgen a long timeago and cant remember.
R.I.P.
Old August 14, 2007, 11:46 AM
Rapid-X's Avatar
Default ok system back but still a huge problem?
i tried the safemode msconfig that worked then it restarted like 2 hours later so i powered down removed and reinserted the cpu .. works like a charm only one problem now, no drivers. i dont want to reinstall xp again any ideas how to get my drivers back...
BTW hardware devices shows blank lol i screwed this one up
Last edited by Supergrover; August 14, 2007 at 02:47 PM. Reason: Offensive Language
Old August 14, 2007, 12:18 PM
b1lk1's Avatar
Time to reinstall windows.....................
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old August 14, 2007, 09:53 PM
Rapid-X's Avatar
Default FIXED
thanks for all the help but my little brain came up with the solution ... if anyone has or gets this problem just go into administration tools- services and enale all services and tadaa its back to normal ...sumhow it stopped and diasabled all of the drivers and services..
Artifacts in ATI tool? magictorch Troubleshooting 7 February 25, 2008 01:33 PM
BIOS Chip removal tool? mattydies CPU's and Motherboards 10 February 15, 2008 01:06 PM
Want to look like a Tool and wear your ipod on your Head? Cptn Vortex Audio 8 December 15, 2007 02:52 PM
Best Image resizing tool for Vista X64? Patriote O/S's, Drivers & General Software 5 November 8, 2007 07:47 PM
AMD GPU Clock Tool v0.7 released Babrbarossa CPU's and Motherboards 2 May 4, 2007 02:35 PM
