Old August 28, 2009, 06:16 PM
ToXic's Avatar
Default Thermal room on i7 920 @ 4.00
so i just pushed my 920 to 4.00 Ghz and am reciving a temp of about 70 acrossed all the cores under Prime 95 load. Should i clock it down or is this a safe place to be right now?
Some kind of pathetic Apple convert
17" Macbook Pro (early 2011 model)
2.2Ghz i7-2720QM | 8GB Corsair DDR3 1333Mhz | 750gb Toshiba HDD | ATI 6750M 1GB
Old August 28, 2009, 06:18 PM
werty316's Avatar
I wouldn't worry until it hits 85°C.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old August 28, 2009, 06:24 PM
Arinoth's Avatar
which prime95 test are you doing, each stress the cpu differently and those are good temps. Hopefully your ram voltage and FSB aren't above the manufac recommended
Old August 28, 2009, 06:27 PM
ToXic's Avatar
no but i got BSOD'd
going to try again.
Old August 28, 2009, 06:32 PM
Arinoth's Avatar
Well be careful, do it in slow steps so you don't brick your rig
Old August 28, 2009, 06:36 PM
ToXic's Avatar
what should my core VTT be at right now im +150MV
found out my VTT should be +250... fixed, retesting on prime
Old August 28, 2009, 06:49 PM
baby steps man, baby steps.
Old August 28, 2009, 06:54 PM
ToXic's Avatar
iv pushed myself back to my stable 3.2 Ghz clocking i mean all i bought a 920 for was to subvert intels crazy pricing, and with 3.2 Ghz iv saved myself over 1000$. Honestly 3.2 is a good speed for a gamer across 4 (8) cores.
only thing i forgot to do is reset my fans PWM temp ranges haha.. but 61C on 700RPM
Router and modem in furnace room ??? crazyhorsejohnny Networking 6 August 17, 2009 07:45 AM
Voltage regulator block (Thermal tape or thermal counpound?) Mavvens Water Cooling 5 August 8, 2009 06:56 PM
If you make this shot ... I'll paint my room pink! .... ADay2Long Off Topic 14 July 29, 2009 01:05 PM
Room for soundcard? o_o Formaldehyde New Builds 6 November 13, 2008 06:50 PM
Ottawa Room for Rent, good access to schools! Cheator Off Topic 4 August 13, 2008 06:47 AM
