Old August 25, 2009, 01:25 AM
chouchou's Avatar
Default Timings for my 2x2GB Redlines on a 750i FTW. Also, voltage questions.
Running a q6700 at 3.3
wondering what kind of timings i should use with this setupp. Have my mem voltages at 2.1v, and all my other voltages at auto.
I realize that the voltages on auto aren't good for one's CPU/other settings.
What should i have mine set to? According to CPU-Z, my q6700 at load is running approx 1.24v
EDIT: BSOD 2 hours into Prime 95 small ftt's.
updated my voltages:
CPU Core - 1.434
CPU FSB - 1.30
Memory - 2.1
NFORCE SPP - 1.45
NF200 - 1.30
Will test agian.
Also, the ram/cpu freq's are linked at a 3:2 ratio.
Cheers
HAF932
Q6700stock || SLI GTX 260 c216 =) || 2x2gbMushkinRedline PC2-8000
750i FTW || WD 36GB Raptor || WD 640GB Caviar Black || HX620W
Old August 25, 2009, 02:25 AM
Jackquelegs's Avatar
small ftt fail usually indicates that your CPU is unstable.
Menu > Advanced Chipset Features > FSB & Memory Config > Memory Timing Setting
tCL (CAS Latency): 5
tRCD: 5
tRP: 5
tRAS: 12
Command Per Clock (CMD): 2T
** Advanced Memory Settings **
tRRD: 4(3-4)
tRC: 31 (26 if maximum value)
tWR: 6(5-6)
tWTR: 11(9-11)
tREF: Auto (7.8us)
*I recommend
tRRD: 3
tRC: 24-26
tWR: 6
tWTR: 11
tREF: 7.8us
Menu > Advanced Chipset Features > System Voltages
Memory: 2.1v
nForce SPP: start from 1.35v, increase if needed
FSB - Memory Clock Mode: Linked for better performance, unlinked for stability
MEM (DDR), Mhz: 1000mhz or 1066mhz
-Redlines usually can do 1066mhz.
-The CPU voltage is high enough already, but CPU FSB voltage can be raised though. 1.4v seems to be the sweet spot for your FSB
-Disable Intel Speedstep and C1E function
-PCI-e Frequency 100, or 101
-You shouldn't need to play with the GTL voltages just yet.
Iapetos
Zephyranthes
Old August 25, 2009, 02:28 AM
chouchou's Avatar
okay sounds good. do you start from high to low in regards to core voltage?
HAF932
Old August 25, 2009, 02:32 AM
I made some changes while you posted btw.
Yes for the 65nm Quad you should start your voltage at 1.35ish for that FSB, I recommend using a good FSB number like 333mhz for 333x10 effective.
Just start at 1.35, and work your way up.
Remember, that not all crashes are due to solely the CPU or RAM. Sometimes it's a combination of both. Make sure you try to eliminate possibilities of instability before you boost crazy voltages.
Iapetos
Zephyranthes
Old August 25, 2009, 02:48 AM
chouchou's Avatar
alright. after vdroop load the cpu is running at around 1.36v. i think in bios its arond 1.42500v
nforce spp at 1.40 and cpu fsb at 1.30 (1.40 is redzone according to evga bios)
running prime 95. will sleep and wake up and see what happens. if no bsod im going to lower the vcore until i bsod after 5 hours prime 95.
whats a stable prime 95 duration for you?
HAF932
Old August 25, 2009, 02:50 AM
First overclock on a new platform/CPU is always overnight, at least 10 hours for me.
Run Prime95 Blend test.
Iapetos
Zephyranthes
Old August 25, 2009, 02:53 AM
chouchou's Avatar
alright tyvm. i'll let you know how it goes. is 3.3 a decent overclock or should i push for 3.5?
HAF932
Old August 25, 2009, 02:55 AM
I like to use nice numbers for day to day uses. 333mhz -> 400mhz.
Trust me, you'll be happy with 3.33ghz. Buy an SSD
Iapetos
Zephyranthes
Old August 25, 2009, 03:02 AM
chouchou's Avatar
Haha alright sounds good. Thank you much for all your help! Until tmrw
HAF932
np Cya
Iapetos
Zephyranthes
[FS] gtx260's, tx750w, e5200, 750i FTW Phobia Buy/Sell & Trade 14 August 4, 2009 06:39 PM
[FS] eVGA 750i FTW /w bios update DavidDemise Buy/Sell & Trade 5 March 25, 2009 10:21 PM
Timings for 2x2b Redlines PC2-8000 chouchou Overclocking, Tweaking and Benchmarking 8 March 19, 2009 10:30 PM
[WTB] EVGA 750i ftw TerenceJ Buy/Sell & Trade 2 March 15, 2009 06:04 PM
HAF932 + EVGA 750i FTW + WC magelan Case Mods, Worklog & Gallery 8 January 24, 2009 12:06 PM
