Old August 24, 2009, 05:53 PM
ebdoradz's Avatar
Default unlock PII and instability
i have unlock my PiII x3 720 be to 4core. but i have some instability issue...
the screen freeze but i dont have any blue screen or something similar..
i have some ddr3 balistic runnig @ 1600mhz on recommendetiming and voltage... i have also set cpu vcore to 1.35V ....
between the usual test any idea???,..... i dont have the time right now to do all the test.... i just want to have your opinion
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old August 24, 2009, 06:07 PM
considering that there is probably a reason that the phenom II x3 were binned to x3 and one core disabled, there is a high chance of that disabled core being a defective one
Just like over clocking, YMMV
Intel Core 2 Duo e8400 @ 3.8GHz
Mushkin Ascent 1x2gb
Asus P5N-D
BFG Geforce 8800GT OC SLI (folding issues...)
WD 500GB
NZXT Apollo
OCZ Vendetta 2 w/ Bolt-thru kit +Scythe S-Flex F
Syncmaster T220, Razer Deathadder, Lycosa Mirror Edition, X-240 speakers
Old August 24, 2009, 09:38 PM
CanadaRox's Avatar
Disable AMD Cool and Quiet as it will try to run voltages designed for an X3 instead of X4. Also, bump up the CPU voltage by 0.1V and see if that helps. And of course, it is always possible you have just gotten a chip that doesn't want to unlock.
Project: Black and White
Old August 25, 2009, 05:21 AM
sswilson's Avatar
You may also have to bump the bus voltages as well. I've got a sneaking suspicion that adding the extra core puts 1/4 more stress on the bus' but doesn't automaticaly compensate by raising the NB (etc....) voltages.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old August 25, 2009, 10:51 AM
Silvgearx's Avatar
what are your ram timings? and which ram set?
have you tried setting rams at 1333mhz, timings 7-7-7-x ?
and i believe you tested your 4th core in prime95 right?
and your running all 4 cores at stock?
Old August 25, 2009, 03:07 PM
ebdoradz's Avatar
BL2KIT12864BA1608 - 2GB kit (1GBx2), Ballistix 240-pin DIMM , DDR3 PC3-12800 from Crucial.com
8-8-8-24 1T @1.8V
tired lower 1033 @7-7-7-20
and i believe you tested your 4th core in prime95 right? for1 hor but nuthing more
and your running all 4 cores at stock? yes
AMD cool and quiet is the 1st thing that i disable in bios.... i have overclock lotsof 939 and am2 but those am3 chip aren't the same thing ....
Old August 25, 2009, 03:09 PM
ebdoradz's Avatar
have you tried to unlock your,s???
Old August 25, 2009, 05:33 PM
Silvgearx's Avatar
when i read about 720BE unlocking and overclocking, some people had to put there NB to 1.3v-1.5 to get stable clocks
still a n00b in learning :P
Old August 25, 2009, 06:34 PM
ebdoradz's Avatar
put my ram at 1333 7-7-7-20 1t and so far its gone.
Old August 25, 2009, 06:48 PM
sswilson's Avatar
Yes, but I'm having issues on the PCIe bus. I can unlock the 4'th core, but as soon as the Nvidia drivers start to load up it freezes on a black screen.
I can get into windows with the 4'th core if I get rid of the vid drivers and rely on the default windows ones. I ran into exactly the same issue with OC on 3 cores, but was able to make it go away by increasing the bus voltages so I suspect that's where I need to look, but haven't had the chance to dedicate the time required to get it right.
[WTB] Q6600//pii 940//pii 720 phil3_66666 Buy/Sell & Trade 0 May 4, 2009 02:51 PM
[WTB] PII 266 mHz Processor JephDiesel Buy/Sell & Trade 8 February 24, 2009 08:13 PM
Help!! I can't unlock these RAID Drives!? bushwickbill Troubleshooting 38 July 30, 2008 10:51 PM
Severe System Instability Salavat23 Troubleshooting 26 February 6, 2008 08:56 PM
