Old August 4, 2009, 09:54 PM
shayan288's Avatar
Default Q9550 Overlocking
Hi all,
I have a q9550 E0 stepping that I have overclocked to 3.8ghz (OCCT and P95 stable) and I am trying to get it to 4ghz
However.. It seems impossible, I even tried 3.9 and it didnt work...
Settings:
Vcore 1.36250
FSB Volt: 1.4
Someother stuff that I will have to look at if it must be known.
I dont have a case at the moment and I am using a OCZ Vendetta 2 cooler (stock fan) (Is there a possility that I can get an improvement by sticking a yate loon on to the vendetta 2?)
Thanks in advance.
PS. I am using a EVGA 780i MOBO and I do NOT have the latest BIOS version... Could that be a reason? Is it worth flashing the BIOS?
PSS. What is strange is that when I am running OCCT or orthos/P95, My temps would never go above 55C.. and yet at 4ghz it would fail after like 4 minutes.
s288
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old August 4, 2009, 10:28 PM
Eagle Eye's Avatar
Try dumping 1.4v into that chip and see if it posts, I know my chip needs at least that to be completely stable at 4.0GHz.
Old August 4, 2009, 10:43 PM
shayan288's Avatar
Yikes!... Isnt that like.. dangerous? I heard somewhere that 1.36250 was the max recomended volt for the q9550 and that anything above that would cut the "life expectancy"... Is that true? If so, how much of the life expectancy would it cut?
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old August 4, 2009, 11:27 PM
Eagle Eye's Avatar
Its been much debated about, I personally don't think its going to kill my processor anytime. If someone says otherwise I will drop my voltage and backoff to 3.8GHz, because its not like 200MHz makes any difference performance wise.
Old August 4, 2009, 11:39 PM
shayan288's Avatar
yeah true, anyways, I just tried 1.4 vcore and it was unstable so im trying 1.41850 atm :S
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old August 4, 2009, 11:40 PM
shayan288's Avatar
Weeeeell whaddaya know... UNSTABLE :'( oh well, Il jsut leave it at 3.8 ghz 1.36250 vcore. meh
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old August 5, 2009, 12:00 AM
Eagle Eye's Avatar
It could be the board you're using, its likely that 0.5 divider is causing some issues it does for me especially at higher FSB frequencies. Trust me 3.8GHz is nothing to be ashamed of thats a monster overclock if you ask me, the only thing holding back that system in any game would be your GPU.
If you're still set on hitting 4.0GHz stable, try and find a guide through google I know there are lots of people with similiar setups that have tried the very samething, you might just find out how they did it.
Regards,
EE
Old August 5, 2009, 12:12 AM
its you board holdin you back
a p45 would be better and would require less volts on cpu
you should be able to do 8x500 on a good p45
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old August 5, 2009, 07:43 AM
Eagle Eye's Avatar
I let prime run all last night, core 2 failed after 5hrs, 56mins.
Old August 5, 2009, 10:32 AM
shayan288's Avatar
same man... Mine failed on the 3 hour on 3.8 GHZ!!! :'( I think Imma try 4GHZ on maybe 1.43vcore and maybe bump up the vtt? would tyhat be safe?
And wow I cant believe it... My 780i would hold me down? I thought those boards were supposed to be good... :'( this sucks.
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
[WTB] Q9450 or Q9550 HoTiCE_ Buy/Sell & Trade 1 March 7, 2009 08:39 AM
best heatsink for Q9550 johnnyuterus Air Cooling 11 February 11, 2009 05:26 PM
oc'ing q9550 johnnyuterus Overclocking, Tweaking and Benchmarking 10 February 10, 2009 12:49 AM
Canada overlocking database list hausner Troubleshooting 12 July 6, 2007 02:54 PM
